New 3 bottom plow, who sells them?
   / New 3 bottom plow, who sells them? #1
Doc_Bob
Elite Member
Wisconsin
2003 NH TN70A
I need to buy a new 3 bottom plow (3x14) for an insurance claim. Does anyone make a good 3 bottom plow like my Oliver that went up in smoke two weeks ago??
Doc Bob
   / New 3 bottom plow, who sells them? #2
Doubt there is much call for 3 bottom plows on the new market. Used would be best bet.
Getting a check and not the plow would be a better option. :)
Not much plowing done these days, as no-till seems to be the way to go.
   / New 3 bottom plow, who sells them? #3
Kneverland and Overum do. Big dollars though. How did a plow burn? All the wear steel and hydraulic hose would be garbage but the rest should be ok?
   / New 3 bottom plow, who sells them? #4
In answer to your question, yes there a several manufacturers that make new three bottom plows and I can tell you who they are.
My question is this...
How much do you want to spend. They ain't cheap if you are going to buy new.
Still wanna know who makes "new" plows?
edit
Add Kuhn to what slozuki named.
Also, you can get a three bottom switch plow from John Deere.
The insurance company demands new. I agree with you.
Any links to new would be great!
Hot fire that melted the steel pipe that brings water to the barn and melted the snow-blower frame. I do not want to trust a plow that has gone through that much heat.
   / New 3 bottom plow, who sells them? #7
How old was your plow and does the insurance company know how much they cost?
I bought it used. And the insurance does not know and appears to not care. The policy is replacement cost for like and that means new, not used.
Doc
   / New 3 bottom plow, who sells them? #9
Doc
WOW!
I need to insure my plow.
I gave $800 for it, $300 shipping and I have spent about $300 fixing it up.
so around $1400.
AND...
parts are next to impossible to find for a plow this old and it's a two way so that makes it harder.
A plow similar to mine from any of the manufacturers listed will be from about $7500 for the deere to over 10 grand for the Kverneland. I want (and nearly bought) the Kuhn. $9500 delivered to my door.
CAT Mini Excavator - 301.8 (A59814)
CAT Mini Excavator...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New Holland WorkMaster 37 (A53317)
New Holland...
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A60460)
2013 Ford F-250...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
