Finished My 3rd Function Valve Install
/ Finished My 3rd Function Valve Install #1
Gordon Gould
Super Member
NorthEastern, VT
Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
/ Finished My 3rd Function Valve Install #2
Nice. I'm still trying to decide if I should just do two rear remotes and put a tee in one of the lines so I can control a grapple or add a 3rd function as well.
/ Finished My 3rd Function Valve Install #3
Good job. :thumbsup:
When I got my tractor the options available were for either two or three rear remotes. I chose to go with two. Later I wished I had choosen the three remotes option. You never know what you might want to do in the future.
/ Finished My 3rd Function Valve Install #6
It's hard to know all of the uses you'll face once you own the tractor. I had originally thought of buying a box blade but after reading here I'm now going to build a grading scraper. I figured if I wanted remotes I could install them myself for about the cost of having the dealer install them and I really didn't need them to operate a box blade.
But now I'm finding that it would be nice to have the chute deflector on on the snow blower adjustable from the seat. That a grapple would be nice to have and of course both need a 3rd function valve. The GL40s have the FEL lever mounted to the rear fender very close to the three slots for the rear remotes.
So I love seeing what others do. Like you said, you never know what you will do in the future so it's nice to have lots of options.
/ Finished My 3rd Function Valve Install #7
It seems the prevailing wisdom is that a "true" 3rd function is better solution than some others, such as running off your rear remotes, because you can can perform three functions simultaneously with your right hand on the loader lever (e.g., raise/lower, curl, and close a grapple).
I ended up taking that advice and just installed the Kubota 3rd function kit on my 5240. I saved a ton of money installing it myself, but it was not an insignificant undertaking.
Even after one weekend, I can see the grapple will result in a quantum leap in productivity, given that I have lots of rocks, trees, stumps, and brush.
It seems the prevailing wisdom is that a "true" 3rd function is better solution than some others, such as running off your rear remotes, because you can can perform three functions simultaneously with your right hand on the loader lever (e.g., raise/lower, curl, and close a grapple).I ended up taking that advice and just installed the Kubota 3rd function kit on my 5240. I saved a ton of money installing it myself, but it was not an insignificant undertaking.
I'm not sure what you mean by this but I guess it is a compliment so thanks. I agree that using the rear remote lever down by my thigh was awkward at times. Now I can operate both levers simultainiously with one hand which is much better for me. And I can run the grapple at the same time as any of the bucket motions. I find this almost necessary when trying to pick one particular log out of a pile. The grapple valve has full feathering control too which I like. No switch to choose between functions to confuse me. I am not sure if you would call it a "true" third function or not but I guess I would because I have all three all the time.
May be a dumb question but what is a top and tilt? :confused::confused2:
As they say "The only dumb question is the one you don't ask".
A Top and Tilt is tractor speak for a hydraulic top link and a hydraulic side link. In other words you replace your top link ( TOP ) with a hydraulic cylinder so you can adjust it on the fly as you work. If you have a box blade or grader you know how handy this would be. You also replace one of your side links (TILT ) with a hydraulic cylinder. This allows you to change or adjust the tilt angle of your impliment as you work. Again, very handy for rear blade work where you are trying to maintain a specific road contour such as a crown.
Hope this simple explanation helps a little. When I receive mine from Fit Rite Hydraulics I will post some pictures.
gg
I hope it didn't sound like I don't like the diverter valve systems and kits now available. I think they are great. It is just that it was easier and much cheaper to do what I did plus IMO I got increased functionality.
Gordon. I have to ask, what are all the logs for?
:) I do some small scale logging on my place. I sell to a local sawmill. You could call it my hobby or mental and physical therapy. It also helps me justify buying new equipment :D :D
/ Finished My 3rd Function Valve Install #13
gg
:thumbsup::):D:thumbsup:
Excellent Answer I am new to a lot of this so love the info I pick up, thanks a bunch.
Michelin Floatbib VF1000-55 R32 Equipment Tires (A64194)
Michelin Floatbib...
2008 CM TRAILER 14' T/A ENCLOSED TRAILER (A65643)
2008 CM TRAILER...
Skid Steer Bale Spear (A65640)
Skid Steer Bale...
New 2x27 Ratchet Strap (A65579)
New 2x27 Ratchet...
Danuser 3Pt Post Driver (A66408)
Danuser 3Pt Post...
1997 Ford F-350 4x4 Utility Truck (Diesel), VIN # 1FDKF38F6VEA38713 (A65563)
1997 Ford F-350...
