B7800 Losing Power
/ B7800 Losing Power #1
snmhanson
Underwood, WA
Kubota B7800
I have a B7800 that I bought new about six years ago. Moderate home use over the years and though I have pushed it at times, I have generally kept up on maintenance. Last year I noticed when I used the mower deck it will struggle and bog down when going even slightly uphill or cutting longer length grass. It generally happened only until the tractor warmed up and then it seemed to run fine.
Today I was using my landscape rake to grade our gravel drive. I had the same thing happen where the power just seemed to fade. If I took my foot off the throttle a bit the power would run back up. Basically, it just seemed like I was working the engine too hard, but I have used the tractor for this before and it handled it just fine. In other words, my tractor just doesn't seem to be able to handle the load that it used to. The engine temp reading never got above the "C" on the gauge, but the tractor did seem to get a bit warm under the seat area and I think I was able to make out a slight smell of burning rubber. The tractor also seemed to not want to roll very easily unless I was pressing the throttle with my foot. I am wondering if the brakes are stuck or something causing the engine to work overtime. I have in the past accidently driven the tractor a bit with the brake locked.
I am hoping someone can point me in the right direction, whether this relates to the brakes or something else. It is likely I will have to bring it into the shop, but I would at least like to get an idea of what I am looking at before bringing it in. And it is always possible I could fix it myself. Any idea?
Thanks,
Matt
/ B7800 Losing Power #2
Thanks,
Matt
Are the brakes off:confused:
Change the fuel filter. Sounds like a plugged filter.:thumbsup:
The brake lock lever is up so the brakes should be off. I'll start with the fuel filter.
Thanks!
Matt
/ B7800 Losing Power #4
How long has it been since the hydraulic fluid and filter been changed? Was there any fiber in the fluid, filter or screen?
/ B7800 Losing Power #5
Lose of power means lose of fuel or air on a diesel. If you suspect the brakes put it in neutral and see if the tractor rolls easily when pushed on level ground. Check the fuel cap to see if it is venting. Replace the fuel filter if needed. Check the air filter. Check the fuel system for air leaks. If it is bleeding air it will be leaking fuel from the same place when the motor is not running. Give the motor a good washing and drying and then check for fuel leaks. It may not be one big leak but several small leaks of air that causes it to lose power.
/ B7800 Losing Power #6
My first guess would be air filter, second would be fuel filter. The air filters on these tractors are pretty small and it doesn't take them long to get plugged in dusty loader or mower work. If that is good check the fuel filter.
/ B7800 Losing Power #7
Matt
I'm glad you posted this as I noticed something similar with my B7800 too a few days ago. I only use it in Hi gear two or three times a year and it just would not have the power it had when I used it in Hi last time. If the above posts are correct it will have to be the fuel filter. I put a fresh air filter in my tractor last fall and it has not seen any dust during the winter for sure. So. I will start with the fuel filter and see what happens. Please post something about it in case you are able to change the filter before I do. I will do the same but it will be a few days to a week before I get to it.
here is a thread about purging the air from the fuel line
www.tractorbynet.com/forums/kubota-owning-operating/127778-bleeding-fuel-line-3030-a.html
I ran to the shop and bought a new air and fuel filter. Replaced my air filter and the old was was pretty dirty. Couldn't see light when looking inside it on a sunny day. Haven't gotten around to the fuel filter and I haven't put any load on the tractor to determine if it was a dirty air filter.
However, I pulled the tractor into the garage where the ground is flat and smooth. I tried to push it while it was in neutral as whistlepig suggested and it wouldn't move. It rocked back and forth like a car that is stuck in gear but the wheels wouldn't turn. I am still wondering if the brakes aren't stuck somehow. Are the brakes something I could check out and possibly work on myself or should I haul it to the shop? Like I said, I did drive it a few times in the past with the brake lever engaged so I wouldn't doubt that there is an issue with the brakes. Or could this be something as simple as time to change the HST fluid?
Thanks,
Matt
/ B7800 Losing Power #10
Thanks,
Matt
Was your range lever in neutral? It will act like it is stuck in gear when you try and move it if the range lever is still in high or low. It is trying to pump oil backwards so there is quite a bit of resistance. If everything is in neutral and you cannot move it then you may have a brake problem.
I initially tried to push it while it was in low but then popped it into neutral and it still wouldn't move. I gave it a good quick try and then gave up but I assume it would move right away if it was going to move at all. It looks like to work on the brakes I would need to get into the transmission at some level, right?
Thanks,
Matt
/ B7800 Losing Power #12
Thanks,
Matt
Do your brake peddles move freely? Sounds alright like a brake problem. Linkage binding or something holding the brake on.:confused:
They brake pedals don't actually seem to move very freely. They work and apply the brakes when I push them but there isn't much movement in them. Kind of like when I push them down they don't really move but the resistance just builds up. I didn't have much time to look at it yesterday and was basically only able to see where the linkage went back to the transmission. I'll take a closer look today and see what I come up with.
Matt
/ B7800 Losing Power #14
Matt, Did you end up finding the problem? It sounds like you have a break issue.
Since I posted I did replace my fuel filter and it did solve the engine bogging down under load problem. It was most noticeable in HI range. Now it works fine.
/ B7800 Losing Power #15
sounds like not enough free play in the brake pedal(s). the adjustment procedure is in the owners manual and is fairly easy.
to get to the internal part of the brakes (if the adjustment doesn't work) you need to remove the axle housings on each side and it is quite a job for a novice.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
Hickory Lumber (A65640)
Hickory Lumber...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
2008 DRAGON  130BBL VACUUM TRAILER (A65643)
2008 DRAGON...
2022 KUBOTA SVL75-2 SKID STEER (A65053)
2022 KUBOTA...
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
