Ever start a fire?
/ Ever start a fire? #21
This Firetruck got stuck due to a leaky hose connection. This happened today. The fire got extremely close to it.
The fire destroyed the landowners barn and the surrounding 5 acres. The barn housed a JD Gator, Snapper mower, 5x10 trailer, Fertilizer spreader, and other misc. stuff.
The landowner had burned a pile of debris on Wednesday of this week and then he received approx. 2" rainfall on the leftover ashes. Fastfoward to today and the humidity drops and the winds blow hard and the seemingly extinguished fire rekindles and embers are blown into his adjacent broomstraw field resulting in the loss of his barn.
/ Ever start a fire? #22
Yes happens all the time out on the west coast. As many as 25% of the fire starts on the coast of Ca are from equipment and mowing.
Some counties in California require a permit to be obtained (before starting work) when extreme fire conditions are present. I have seen stories of a weedeater with a blade starting fires before.
The difference between the east and west is that the west has very low humidity most of the time and especially during the summer. The east experiences its lowest humidity values during this time of year and then we all know how humid and muggy it gets during the summers.
/ Ever start a fire? #23
i have never heard of a mower catching something on fire. but i can honestly believe it. even without others stating it.
having to put out fires, or an attempt to keep them controlled. you would be amazed what little amount of wind and dry stuff it takes to get what you thought was good. to become a major problem very quickly. all it takes is one little hot piece floating over to another spot. and there goes a blazing roaring fire.
as far as blades hitting a rock and making a spark. i can easily believe that. if ya ever used a grinder, or even a sander and hit some metal. it does not take much at times to get a spark.
/ Ever start a fire? #24
I was mowing a lake lot that had a debris pile located in the middle and a garage on the other end. After mulching the pile(which contained some rebar i started clearing around the garage. After making a few passes around it I noticed smoke. I immediately shut down and looked my machine over. It was fine. I looked at the garage and leaves on the roof were burning. By that time the owner had a hose going and put the fire out. The pile was 100 feet away from the Garage.
/ Ever start a fire? #25
So a spark from the rebar started the fire on the roof? That's a million to one shot.
When you are trying to start a fire it's darn near impossible sometimes. But when it's the last thing you want to do it happens like this with a spark flying 100 feet and landing on a roof.
/ Ever start a fire? #26
I was mowing a field with the Takeuchi and Davco and after making a pass and turning around I climbed back up the hill and could see smoke.
I crested the hill and a small fire had started in the field. I immediately looked in the mirror expecting to see the machine on fire but it was not. I attempted to "mow" the fire out but that didn't work and it lit the material on the mower. I tipped/flipped the mower and got most of the debris off and hauled butt across the field to my truck and called 911.
The best I can tell it was the blade hitting a rock and creating a spark. Anybody ever hear of this or have another idea? The machine and mower were checked and showed no signs of burnt debris anywhere (except on top where I caught it on fire)
We have some very dry conditions right now and it went up quick.
The fire dept shows up drives a tanker out in the field, blows the tranny and got swallowed by the fire. No one was hurt and they contained the fire to this 8 acre field but the truck was a total loss.
Wow...I don't usually visit this section of TBN, but the headline caught my eye...Funny thing is, I saw the headline of this story on another site I'm on (FirefighterNation)...
http://www.firefighternation.com/forum/topics/connecticut-fire-engine
/ Ever start a fire? #28
I did the same thing with my rotary mower on my old machine minus the burnt fire truck. I hit a rock and it threw a spark and lit up dry leaves. It was late fall when it was really dry. I jumped out of the cab and tried to snuff it out with my jacket but it was windy and the fire just took of. Fire department came quickly and put it out before it got too bad. I'm shocked it's that dry up there this time of year. In the Northeast we don't worry about starting fires like that, but it happened to me also. I'm glad no one was hurt, and I'm sure the fire truck was insured.
/ Ever start a fire? #29
I put out a fire off the right of way. The trail dozers pushed a burn pile to the side to early and the wind kicked up later that day and ignited the pine forest. Me and the excavator were the working late and headed back to the truck. We were the only workers on site except for an inspector. My hoe operator saw it and got me on the radio. By the time I got there with the Tigercat 480 he it was climbing the trees in about a quarter acre. I cut a circle around it taking down 8 to 12 inchers then backed dragged deep to expose more dirt . After two wide it was contained. It was last summer and extremely dry. It would of took a hundred acres in no time.The water buuggies shower up and said can we get in there and with my adrinalin flowing I said **** yea, I just made a road!
/ Ever start a fire? #30
Around here some people do controled burns on their pastures and hay meadows when the conditions are right. But, you ask an ole' timer here "Have you ever burned your pasture?" and you'll get "Oh sure.......well not on purpose."
Charlie
Sdlanch SDLD25 (A60463)
Sdlanch SDLD25...
ALLMETAL MOBILE PRESSURE WASHER (A58214)
ALLMETAL MOBILE...
2017 INTERNATIONAL 4300 4X2 26FT CDL REQUIRED BOX TRUCK (A59906)
2017 INTERNATIONAL...
207282 (A52708)
207282 (A52708)
2019 ALLMAND LIGHT PLANT (A60736)
2019 ALLMAND LIGHT...
(15) Polyethylene Road Bed Protection Pads (A60463)
(15) Polyethylene...
