Oil & Fuel All fluids change on a Ford 1900
   / All fluids change on a Ford 1900 #1
kasedian
Kansas
Ford 1900
Hey all. Long time observer, first time poster.
Anyways, I've purchased a little Ford 1900 in the past year. It's a 4wd. I dont know the history of it but, it seems to run fine and is in fairly descent shape. I dont have an owner's manual. Ive changed the oil already. Went with Schaeffer's 7000 10w-30, and a Wix oil filter. Im planning on changing the rest of the fluids, and want to know what kinds I need. Planning on changing out everything. Front diffy, power-steering, and transmission? Is the hydraulics part of the rear drive? Im fairly new to this, but want to do it right and would like some "expert" opinions. Thanks guys!
   / All fluids change on a Ford 1900 #2
You need to buy an operators manual or a repair manual. It will tell you the right fluids and the proper capacities. And a lot of other useful info. There are several IT manuals on ebay now.Here are a couple of pages to help you out.
Bill
   / All fluids change on a Ford 1900 #3
Here is the pic for the final reduction
Thanks for the info. I stopped by the New Holland dealer the other too, and asked the same question. He got his big book out, and it showed to use a a "134D" fluid for the front differential and each of the final reduction gear boxes. So, I bought a gallon of the Multi-G 134. About $18. His book also showed that each final reduction only took .23 quart. I wonder why there is such a difference between that and the operators manual that says to fill it up to the bottom of the fill hole with 80 or 90 weight oil?
   / All fluids change on a Ford 1900 #5
yikes...
generic utf meeting M2c134 spec would have been fine.
5g jug for 25$ at many places!!!!
in fact.. I posted to your other thread about this!!!
ask more questions before spending more money...
soundguy
Anyone know?
   / All fluids change on a Ford 1900 #7
won't be the first time I have seen misprints in manuals..
or model changes.. etc..
soundguy
So, which one is the misprint?
   / All fluids change on a Ford 1900 #9
I think it's .23 gallons. 134 was the oil Ford recommended.
   / All fluids change on a Ford 1900 #10
Neither is right.
Fill till it comes out the hole.
2006 Ford F-250 Service Truck (A56858)
2006 Ford F-250...
2018 Caterpillar 308E2 CR Midi Excavator (A55973)
2018 Caterpillar...
2009 Sterling Acterra Altec DM47 TR 47ft Insulated Digger Derrick Truck (A55973)
2009 Sterling...
LOT: (80 approx.) Gallons of Chevron Delo 400 XLE SB SAE 15W-40 Synblend (A59076)
LOT: (80 approx.)...
DEUTZ MARATHON...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
