Quick hitch
/ Quick hitch #21
With respect to this question, I took a closer look at close look at my QH this morning, and the flat bars that swing out to hold the implement on the lower hooks only span about half of the width of the hook opening. I looked and couldn't find a way to adjust them so that they protrude further, so I think I will contact Land Pride and inquire about it.
Again, thanks to everyone who responded.
I have the same question as RRILEY below, Do you at least have bushings on the pins? The locking bars on both my QHs don't span the entire width. but with the proper bushings it could not slip past.
Did you notice if those lock bars are only held under spring tension. I was gonna check mine.
Do you have quick hitch adapter pins from 7/8 to 1-7/16 on your mower pins? maybe this will help fill the void on your quick hitch to help keep it from so much movement.
/ Quick hitch #22
Ill try to post a page to help out,
Home Contact Shopping Cart Check Out My Account Policy
Browse The Store: Product Search:
view shopping cart Items: 0
Three Point Hitch
Top Links
Lift Arm Bushings
Swinging Drawbar
Stabilizer Arms & Pins
Drawbars
Lift Arm Level Assy Cat 1
Top Link Replacement Screws
Top Link Bushings
Quick Hitch Adapter Kit
Lift Arm Pins
Replacement Balls
Drawbar Grab Hook
Top Link Pins
Lift Arm Weld On Ends
Adjustable Lift Arm Pins
Weld-on Top Link Ball
Weld-on Lift Arm Ball
Lift Arm
secure shopping
Three Point Hitch > Quick Hitch Adapter Kit
Item Name/Description Qty/Price Each Qty
QUICK HITCH REPLACEMENT PINS #D-10228
2 SLOTTED SPRING CLIPS 7/16" X 1-1/2"
Sale! $1.22 Each For Any Quantity
QUICK HITCH ADAPTER KIT CAT 2-3 #D-10226
CATEGORY 2-3
CONTAINS: 2 ADAPTERS 1-1/8" ID X 1-7/16" OD X 2-3/4" LONG. 2 SLOTTED SPRINGS 7/16" X 1-1/2"
Sale! $10.38 Each For Any Quantity
QUICK HITCH ADAPTER KIT CAT 1-3 #D-10222
CATEGORY 1-3
CONTAINS: 2 ADAPTERS 7/8" ID X 1-7/16" OD X 4" LONG. 2 SLOTTED SPRINGS 7/16" X 1-1/2"
Sale! $11.00 Each For Any Quantity
QUICK HITCH ADAPTER KIT CAT 1-2 #D-10219
CATEGORY 1-2
CONTAINS: 2 ADAPTERS 7/8" ID X 1-1/8" OD X 4" LONG. 2 SLOTTED SPRINGS 7/16" X 1-1/4"
Sale! $19.01 Each For Any Quantity
Security Policy Privacy Policy Site Map Feedback
Copyright ゥ 2011 Belarus Tractor International All rights reserved.
Powered by: AAcart Shopping Cart Software
search Ag Supply - Roller Chain, PTO Shafts, Hitch Pins, Cab Cams, Sprockets, Set Collars, Top Links, Tractor Seats, Pulley 3 point attachment parts.
/ Quick hitch
In answer to the question as to whether I have bushings on the implement pins, the answer is, Yes I do.
In answer to RRILEY's question, yes, the lock bars are held by spring tension.
OK, I realized as soon as the incident happened that I erred in judgment in transporting my equipment in that manner and immediately remedied the situation, yet I have been repeatedly taken to the wood shed in this thread, so I have also learned another valuable lesson. You can believe me when I say, from now on I'll keep my lessons to myself and never write another similar post, nor will I respond further to this one. I just thought it would be helpful to others who may do the same thing, so fire away fellas. (Edited to say thanks to those who stated their appreciation for what I was trying to do.)
/ Quick hitch #24
Santa,
Thanks for the post. It's a good lesson.
Joe
/ Quick hitch #25
Don, those naysayers don't speak for all of us on this board. :mad:
The ones that tend to flame others for admitting their mistakes need a lesson in manners. You seem to care about others or you wouldn't have posted here in the first place.
Those who belittle others probably would never admit their mistakes on this board. Their intimidating actions no doubt keep others from posting their experiences, thus causing us to lose out on any valuable information they may have to offer.
I for one have a quick hitch. It also has a spring loaded lock, as I'm sure most do. I didn't know it could come unlocked in transport. That information is beneficial to all that use the quick hitches, as they will probably take action to make sure they don't come undone during transport.
Just getting that information out is good to know and may save someone's life.
So you done good. :thumbsup:
/ Quick hitch #26
Ditto, some folks don't seem to read the entire thread before commenting sometimes. I always stop in here and catch up, the life I save may be the readers' here:thumbsup:
/ Quick hitch #27
I also thank you for your Safety post. I am quite new to using a quick hitch and never thought anything would come off it, I was about to trailer my tractor with a box scraper to repair a road for our local gun club. Now I will ensure it chained down. Thank you for post.
PS: I like the idea of turning your top hook upside down.
2022 JCB 509-42 TELESCOPIC FORKLIFT (A65053)
2022 JCB 509-42...
2016 COTTRELL CX09LS2 T/A CAR HAULER TRAILER (A59914)
2016 COTTRELL...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
Mahindra Emax 22S Loader Tractor (A66285)
Mahindra Emax 22S...
Doo Little XTM-8418 Trailer (A66285)
Doo Little...
2022 EZ-GO ELITE...
