Raised the front wheels!
/ Raised the front wheels! #1
TNTractor1
Jackson, TN
2011 JD2520
So, I made my first rookie mistake. After using my new 2520 to mow, I was slowly pulling into the garage to line up with the FEL I had removed. I was creeping along and the tractor stopped moving and the front wheels barely came off the ground... I froze... My mind was racing trying to figure out what was wrong. You guessed it, I failed to lower the ROPS. Once I realized what was happening, I slowly reversed course! Thankfully I was only creeping along, so no garage damage (or me damage). From now on I put my tools right in front of the garage to remind me to check the ROPS.
/ Raised the front wheels! #2
It is amazing how many times that happens to people.
Hasn't happened to me yet ... but I've come really close.
The tools in the path idea is good ... I think I'll do that.
MoKelly
/ Raised the front wheels! #3
MoKelly
If you think you'll forget the ROPS, what makes ya think you won't forget to put the tools out as a reminder?
You need to make it a habit (or routine) to check that ROPS position when ever you leave or enter the garage/shed.
I'm in the habit of driving out of the garage...stopping the tractor and put the ROPS up, then do a "preflight" of the tractor. Same thing applies going back in (except dropping the ROPS).
Once you have habitualized this process, it will be automatic.
The other thing I read (on TBN) was to affix a sign to the lowest section of the garage door (type of door that raises and lowers) as a reminder. When ever the door is opened, the sign (on a chain or similar) is hanging down.
I haven't done this (yet), but I think it's a good idea. I'd make it bright orange.
I'm in the habit of driving out of the garage...stopping the tractor and put the ROPS up, then do a "preflight" of the tractor. Same thing applies goingback in (except dropping the ROPS).
The other thing I read (on TBN) was to affix a sign to the lowest section of the garage door (type of door that raises and lowers) as a reminder. I haven't done this, but I think it's a good idea.
Good ideas. I remember the tools because I usually have to take a hammer/mallet and screwdriver to get the ROPS pins in and out. Once I raise the ROPS I lay the tools I just used down right in my path at the edge of the garage, so I see them and remember to use them again to put the ROPS back down. I am getting better at my "routine" when starting and finishing tractor work :thumbsup:
/ Raised the front wheels! #5
I have done it and probably will again but I never raised the front wheels so far though! :D
/ Raised the front wheels! #6
I have to remember that the next time I have to change my front tires. :D
/ Raised the front wheels! #7
Since I do things like that more often than I am willing to admit to, my current garage door has a 10ft. high door. I also made it higher than standard so my truck with shell and ladder rack would fit. It won't fit in a standard height garage either. Don't ask me how I know this.:ashamed::ashamed::ashamed:
/ Raised the front wheels! #8
I don't have that issue with the shed I park my tractor under, but I like the idea of suspending a low clearance "warning" bar maybe three feet in front of the REAL bar, which is the garage door itself. If you have the ROPS up, and it hits the low clearance "warning" bar first, then you have time to stop and back up before you do some real damage. Of course, if you park your tractor in the garage attached to your house, that idea might not be kosher with the wife unit.
/ Raised the front wheels! #9
This is what I did to remind everybody to lower the the rollbar on the new tractor, the ford 3000 with the fixed rollbar would just clear the door the kioti won't.I only get to the farm about once a month so I wanted a reminder.figured when the pvc pipe busted it would get my attention.
/ Raised the front wheels! #10
Strange: out of three folding ROPS I have, none needed tools to remove or install.
/ Raised the front wheels! #11
My ROP does not fold down and that maybe a good thing. After hitting my mothers clothes line with it I'm now more aware of the ROP and always make sure I have clearance. If I had the option of folding it down, I might stop thinking about it and that might mean trouble.:confused2:
/ Raised the front wheels! #12
You could add a sun-shade, & since it's happening in front of you, you'll be more likely to see the sun-shade about to collide with something.
I made a sun-shade out of plywood, so it only increased the overall height of my tractor by 1/2".
/ Raised the front wheels! #13
Probably paint build up in the holes. Reckon it'll wear in after a bit.
My 2000 Deere 4400 folding ROPS still requires a tap though, but the palm of my hand normally suffices.
/ Raised the front wheels! #14
That's a good idea. Just watch for shards of that plastic when it flies (especially during cold weather).
I think mine require a tap with tools mostly because it's brand new... it does seem to be loosening up a bit lately though.
/ Raised the front wheels! #16
see pic. *shrugs*
i suppose another thing you could do is. get them long CB antennas for trucks and cars. or what you might see on vehicles that run in front of over sized load semi trailers. to double check there is clearance before semi gets to a given point. and fix them to front of tractor ((mowing under trees for example)) might help as well.
UNUSED WOLVERINE 3PT QUICK TACH (A64281)
UNUSED WOLVERINE...
2006 Chevrolet Silverado 2500HD Ext. Cab Knapheide Service Truck (A61573)
2006 Chevrolet...
Bulk Lot of NEW Motorcycle Control Cables - Motion Pro & Biker's Choice (A63118)
Bulk Lot of NEW...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
PALLET FORK ATTACHMENT FOR MINI SKID STEER (A61572)
PALLET FORK...
UNUSED GOODYEAR 380/85R46 LSII TIRE (A63291)
UNUSED GOODYEAR...
