School me on the Tombstone
/ School me on the Tombstone #41
I had always read that 2 car batteries in series could weld.
That's 24 volts.
Had a 24 volt 25 amp transormer so guessed that could weld, well it can do, but you need slim rods and striking an ark is tricky however I fixed kids bikes etc.
Later found an industriel transformer that was high volt input down to 110 vac
like for $10. or so, and the frame looked easy to dismantle.
Remember that it had 88 turns of #8 wire for 110 so I did another 88 turns to use 220.
For the secondary or weld coil I used 1/4" copper tubing and about 46 turns.
Poured varathane varnish (twice) to act as insulation.
Some battery jumpers for weld cable, C-clamp for ground and vice grips for the rod holder plus good gloves.
1/8" rod on 1/4 worked great! (6013)
Used different rods depending on thickness as I never could control amperage.
Later got decent mask and good rod holder as orig mask was simply a welding lens ducktaped to a plastic shield made from scraps.
Gotta tell you nothing came apart as I shure had good penatration.
I now have a nice miller AC unit, but like to remember tha good old days.
All this to say, welding is really easy to learn. Not rocket science.
Practice, break apart your welds just to see how good they are and jump in and have fun.
While old bed spring frames are good metal, the temper/hardness or whatever is enough to discourage a beginner so get some decent metal to practice on.
Have fun and good luck.
/ School me on the Tombstone #42
"Later found an industriel transformer that was high volt input down to 110 vac
Some battery jumpers for weld cable, C-clamp for ground and vice grips for the rod holder plus good gloves."
Takes cajones the size of cocoanuts to do something like that. You have my respect, Sir.
/ School me on the Tombstone #43
Shield Arc,
You think the powerarc can do the light gauge materials as well?
How thin of light gauge material? Joint prep, technique, and skill all play together with any type of welding. Mig welding is a great process for welding thin material, but a cheap flux core machine will drive you to drink! Another option with the Power Arc 200 is a scratch start Tig attachment. You'll need a flow meter anyway, but with Tig you'll need a bottle of 100% Argon, where as with Mig you'll go with a Argon mix or 100% Co2.
Welding is not cheap, if you're on a budget, you'll have to make sacrifices somewhere.
/ School me on the Tombstone #44
i weld alot of 12 g - 16 Gage material for my metal art, and you cannot go wring with a small MIG welder. Its amazing how nice these fuse materials without melting thru. and even if you do occasionally do a melt thru, just tune it down, fill the void, grind and sand, and the melt thru disappears.
2021 MULTIQUIP WHISPER PORTABLE AC GENERATOR (A59823)
2021 MULTIQUIP...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
TANK MANIFOLD (A58216)
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A58017)
2018 INTERNATIONAL...
FUEL CELL (A58214)
FUEL CELL (A58214)
DEUTZ MARATHON...
