Tires for Beaver
/ Tires for Beaver #1
ssg510
Any suggestion on replacing my original turf tires on my Beaver. I really like the turf as I use the tractor alot in the yard. What about Ag tires. Thanks
/ Tires for Beaver #2
If you really like turf tires because they don't mess up your lawn, then you'll hate ag (R1) tires. They are designed to engage and bite into the ground. If you're wanting to pull ground-engaging implements like a disk or plow through heavy soil, you will hate your turf tires. Somewhere in between are industrial (R4) tires, like you see on many new compact tractors or industrial equipment. The R4 is a compromise between the two, and doesn't pull as good in soft soil as an R1. It also is tougher on nice ground than the R3 tire (turf tires). The R4s will pull through soft stuff better than a turf, though, and chew up your ground less than an R1.
If turf tires do what you want well, the majority of the time, and have traits you desire, like being easy on the ground, get those again. Some people have had great luck with a mud-terrain pickup tire, for much less money than turf tires.
I had R1 tires on my Mitsubishi D1800. I put R3s on it. Now I can go places and not tear the ground up, but for pulling anything except a tiller (which pushes forward anyway) that digs into the soil it's useless, even though I've filled the tires. I'm ok with that, because I only run the tiller and mower with it. But if I didn't have another machine to pull the disk and plow, I'd be in trouble when I needed to use those implements. With something as little as a Beaver, I'd imagine it matters even more to have the correct tires. Let us know what you decide, and how it works for you!
/ Tires for Beaver #3
Ditto, I got some used 16" pickup tires on my grey beaver. $20.00 each, mounting included.
/ Tires for Beaver
Probably will only use it for fel work and snow removal in winter. Will use chains for that also. Thaks for the help. Bfgoodrich makes a 33x9.5 tire that might work.
/ Tires for Beaver #5
Well, my MT180D (4 X 4) needed new shoes as my rears were very badly weather checked.
Since I rely on the tractor for my snow duties I decided to re shoe rather than have a disaster this winter.
Since my size is 9.5 X 18 I had a real tough time locating them.
Simply not being produced other than by Bridgstone, and at that I question as to when.
You need to have the correct ratio front vs rear, with the front leading a bit for 4 wd operation otherwise damage will occur, (probably front drive).
Gotta say It was costly, tires + tubes + juice came close to $900. but I have no worries now.
While dismounting/mounting we remouved all rust, painted and primed the rims to extend the life.
Thinking I might need a rim, I called around and was stunned at what I would need to pay. (almost the price of both tires!)
Now my turfs with double ladder chains is unstoppable, great on ice, and in summer the turfs don't damage my grass unless I turn in 4WD, then one frt chews up a bit so on grass it is 2WD only.
/ Tires for Beaver
What did you do for tires. What brand and size. Where did you get them.
/ Tires for Beaver #7
Assuming you refer to my post, I went to a very large truck tire dealer in my area.
He did a search and found them in Ontario (I am in Quebec).
I had tried just about all tractor shops (maybe 15 or so) with no joy.
The truck shop was super well equipped to do the work, in fact flat rated the job.
Actually was in and out in about 1.5 hours and that included the cleaning/painting of the rims as well as the beetle juice.
They pumped out the old CaCl as well.
I did bring my tractor to the shop, but they could have come to me for a price as they have shops on wheeles as well.
If I recal, the fee was $40 per tire, all included,
/ Tires for Beaver
What brand did you get. What size
/ Tires for Beaver #9
Follow up on my new tire post one year later.
Just this week as I prepped my tractor for winter I discovered serious checking forming from the rim to about a 2-3 inch band all around the rims.
This on new tires?
A brief visit to the tire shop has resulted in follow up and supposedly I will get a visit from the tire rep shortly.
At least I am being listened to and not blown away.
Oh, and total usage since install; about 50 hours!
/ Tires for Beaver #10
This on new tires?
Today I had a visit from Firestone and the rep confirmed that they would replace my tires!
Guess I live right.
Now where will they get me a pair from? The tire shop had told me that they were the last pair in Canada!
/ Tires for Beaver #11
Just in the last hour the tire shop called to confirm that Firestone would give me a full credit for my 'new' weather checked tires.
The condition is that I return the old (1 year old/-50 hrs) ones, HOWEVER THEY WILL NOT REPLACE THEM!
Am I to run on rims?
Being a 4X4 options get rather slim.
Anyone have a solution to suggest?
As I told them, I did not spend $909.66 to purchase seconds or defective tires.
In fact I am no further ahead just $900. poorer as the old tires had just about the same thread showing.
The dealer is looking for a solution, like maybe truck tire or backhoe fronts.
I am not a happy camper at this point.
Anybody have any suggestions?
/ Tires for Beaver #12
I understand there are not many sets of those tires floating around, but if they will credit you back the money your tires cost, you ought to be able to replace them for that price. You've still gotten a year's worth of service out of them. Tell them to call you when the tires come in, have them swap out the tires at that point.
What is the bolt pattern on your rims? Maybe some other machine's wheels will swap over, and you can find tires that are more available.
/ Tires for Beaver #13
I was told that NO they will not replace but YES a full refund (for tires, not labor) bur I must return the old tires to get the refund.
GREAT, now I have a tractor and no tires to drive on.
The only solution is to have custom rims made up and buy another new set of tires.
BUT, in all probability I'll need to mount new fronts to keep the required ration between front and rear.
The other factor is my main usage is snow removal and that is about to begin any day now.
In summary, to get my $640. credit I'll need to spend(probably) $1000.(or more)
Not a happy camper!
/ Tires for Beaver #14
It's not the same as having the correct turf tires, but I would consider going with an LT285/70R18 mud terrain tire. The Goodyear MT/R specc'ed to run on 7.5 to 9.5" wide rims, and outside diameter is 35.1 inches. According to Pete's tire store those size (9.5x18) tractor tires are 35.2" in diameter. I'm sure whatever the Firestone equivalent is for these would work fine too.
It would be ideal to get the appropriate tractor tire, but if you're out all the money, and they won't do anything else, this may be a way to at least salvage something. Or put a new set of tires on a car? I'm really sorry you're experiencing this; I hope you get it figured out.
/ Tires for Beaver #15
Please post photos showing the checking issues. You may be better off keeping your tires than returning them and having nothing to replace them with. If you can arrest the checking from going any further, by applying some form of chemical treatment (not exactly sure what's out there for this, but there is likely something available), your tires could last for many more years. In the meantime, keep your eyes peeled for a good used set from another salvaged Beaver.
Vvm
/ Tires for Beaver #16
At this time my position tends to attempt for a partial refund and keep my 'new' checking tires.
I see as an option (which I might have done had I known) to foam fill the tires.
Foam would have provided a certain amount of weight, not as much as liquid fill, all while keeping the structural integrity of the tire.
I am sure the foam fill would have cost quite a bit less than the $900 I have spent so far.
Mind you I am sure that I will have at least some 5 years or more before any serious checking occurs as at present the checks are surface, but lots of them (like a 1" band all around the rim area extending outwards in some areas).
As to arresting the checks, I have queried many tire folks and there are no suggestions to rectify that problem. I do believe it is all in the rubber formula at production levels.
Now if this particular tire was 4 or 6 ply I would be much less concerned, however they are only 2 ply.
/ Tires for Beaver #17
Check my post in reply to member "duwem"s inquiry about S373 Beaver III 4X4 tractor. Could be that your 9.5X18 tires can be replaced by Beaver rear turfs in 16" size. Of course, you would need the 16" wheels, too. Beaver had less power, but higher rpm engine, so 16" wheels were probably the best match. Buck had more hp, but lower rpm, so 18" wheels prevented it from having too low of a ground speed. Having 18" on the Beaver III would have bogged it down at lower ground speeds due to too little power.
At one time, I pondered the idea of replacing the 16s on my Beaver III with 18s from a Buck. Doing the math: taking into consideration when Beaver III rpm's reached peak torque and ground speed attained in each gear....when doing the same calculations with the Buck, it confirmed that the gear ratios were the same in both tractors. Lower engine rpm's coupled with larger rear wheels in the Buck were best match for it. Higher engine rpm's coupled with smaller wheels in the Beaver III were best match for it. Putting Beaver III 16 inch wheels on a Buck should put less strain on the engine, but reduce top speed in each gear. Again, just my 2 cents.
Vvm
Vvm
/ Tires for Beaver #18
Using a pair of gyprock T squares clamped together I measure 34" across the treads, i.e. outside diam.
If I recall my fronts measured 22" so I'd need to calculate the ratios keeping in mind that fronts should lead by 5% to compensate for faster wear.
For now I await the tire shop's proposal (s).
By Tuesday I'll do a follow up but so far the shop is being good at communicating with me and I do not wish to 'harass' them.
2024 Kubota RTVX1140 (A64127)
2024 Kubota...
New/Unused Wolverine 72in Quick Attach Ripper (A65583)
New/Unused...
(APPROX. 29) ASSORTED ROUGH SAWN PINE (A64276)
(APPROX. 29)...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
Schuler Feed Wagon (A66408)
Schuler Feed Wagon...
