3 point hitch grapple
   / 3 point hitch grapple
Thanks for all the replys. Got to use the grapple for the first time yesterday. I was helping my Father-in-law cut a large poplar tree and the grapple made clean-up of the limbs quick and easy. I can't believe the power and force this thing has. The design let me load and unload massive limbs and logs with-out leaving the tractor. I am very well pleased with it.
   / 3 point hitch grapple #12
What a truly unique solution! Use the strong end of the tractor for the heavy lifting. I'll bet it makes an excellent skidder too.
Can't wait for pictures!
Joe
   / 3 point hitch grapple #13
Great looking implement. You could market this on a commercial basis.
Could you provide a few of the matarial specs that helped you create this? Boxed frame member guage, size, type of metal, and the rear hydrolics? Or just provide a general guideline, when deciding to create a 3 point monuted design.
I have a JD 4700 and would like to get more use out of my 3 point.
Your welds look very clean, smooth, professional. You must have been in the welding trades.
I do not have much welding experience, but will soon be looking to fabricate some 3 point frame members in the near future, and could use some advice. (on a much more amateur basis than what you have created)
I am in the investigation stage, and will be looking for a welder, stock metal, etc.
   / 3 point hitch grapple #15
Good on your project.
Seems a bit on the heavy side as I look at it, and thinking about sliding into a brush pile. Action shots and a video would be just great to see.
I've been planning a single grapple bar for my Deere forks that would work for FEL or 3 ph. Your build gave me some more incentive.
This is the Deere fork on the iMatch with hyd top cyl.
   / 3 point hitch grapple #17
I've been toying with the same idea, Not sure which to put it on though, the forks or the 6 ft high volume bucket. i just need that little bit of grabbing force to hold those bulky loose loads on.
I modded my forks to work on imatch as well but on the 3 pt would limit you to just moving the stuff around, when I need to move this stuff I usually need to load it up onto a dump trailer, so the loader mount would be used more. But I always like the extra options, and being able to use it on the 3 pt could come in handy I'm sure.
JB.
   / 3 point hitch grapple #18
Right JB
I'm sure I would use it mostly on the FEL work.
Joe
Yes, I works well for skidding also. I will try and post some actions pictures very soon.
Thanks for the welding compliment....no I am just an amateur when it comes to welding....I am a finish carpenter so wood is my thing....just enjoy learning new things. As far as materials, I used 3/16 wall 2 1/2" x 1 1/2" tubing, 2" x 2" x1/4" angle iron and 2 1/2" x 3/8" flat stock. I came up with the design because I wanted a grapple for moving brush and skidding logs. I don't have a FEL for my 3032E yet so this allows me to move brush in a very functional way. As far as the hydraulics, I purchased the rear 2 spool SCV that was available for the JD 3032E. You should be able to add a SCV to your tractor as well.
2024 CATERPILLAR 259D3 SKID STEER (A60429)
2024 CATERPILLAR...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
1607 (A57192)
1607 (A57192)
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Honda EM3500SX Portable Gasoline Generator (A59228)
Honda EM3500SX...
