List of Critical Shop Tools
   / List of Critical Shop Tools #1
John (Toronto)
Port Severn, Ontario
Kioti DK40HST
List of Critical Tools and practical description of what they can do for you! (swipped off the internet)
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh--!'
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
SON-OF-A-***** TOOL: (A personal favorite!!) Any handy tool that you grab and throw across the garage while yelling 'Son of a *****!' at the top of your lungs. It is also, most often, the next tool that you will need.
   / List of Critical Shop Tools #2
I love it
Bench Grinder - used to sharper soap stone and or carpenters pencils and to alter the bevel angle of cold chizels rendering them useless.
Shop Press - used to permanently jam good sockets into the hole you pressed a bearing out of.
Gear / Bearing puller - used to test theories of ballistics when it pops off and sails over your head as you duck, can also be used to test brain motor reaction times of your body (see also spring compressor)
   / List of Critical Shop Tools #3
Lol. This almost always happens to me. A few months ago. I was pulling out a motor and thought I had all the wires disconnected. I kept going up and up with the engine until it wouldn't go anymore.
I go over to look what it's hanging up on. It's hanging up on around 6 wires I forgot to disconnect.
Chad
   / List of Critical Shop Tools #5
Thank you so much for the post. From where did you compiled all these? Appreciate if you will update the list once in a while.
   / List of Critical Shop Tools #6
Heres another for you
EASY OUT named so as to rub salt in the wound when you realise that you now have a hardend broken off object jammed in that inexcesable hole:D
   / List of Critical Shop Tools #7
Real good.:laughing:
   / List of Critical Shop Tools #12
I have got a list something like that on my computer. I'll have to compare and see if there are any missing from that list that are on my list.
They sure are amusing.:laughing:
   / List of Critical Shop Tools #13
WIRE WHEEL: ......
Here are a few more I found on the list I had.
ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their
holes until you die of old age.
WHITWORTH SOCKETS: Once used for working on older British cars and
motorcycles, they are now used mainly for impersonating that 9/16 or 1/2
socket you've been searching for the last 15 minutes.
after you have installed your new disk brake pads, trapping the jack
EIGHT-FOOT LONG DOUGLAS FIR 2X4: Used for levering an automobile upward
off a hydraulic jack handle.
TWEEZERS: A tool for removing wood splinters from hands, fingers etc.
PHONE: Tool for calling your neighbor to see if he has another hydraulic
floor jack.
SNAP-ON GASKET SCRAPER: Theoretically useful as a sandwich tool for
spreading mayonnaise; used mainly for getting dog**** off your boot.
E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known
drill bit that snaps off in bolt holes you couldn't use anyway.
CRAFTSMAN 1/2 x 16-INCH SCREWDRIVER: A large pry bar that inexplicably
has an accurately machined screwdriver tip on the end opposite the
handle.
AVIATION METAL SNIPS: See hacksaw.
TROUBLE LIGHT: The home mechanic's own tanning booth. Sometimes called a
drop light, it is a good source of vitamin D, "the sunshine vitamin,"
which is not otherwise found under cars at night. Health benefits aside,
it's main purpose is to consume 40-watt light bulbs at about the same
rate that 105-mm howitzer shells might be used during, say, the first
few hours of the Battle of the Bulge. More often dark than light, its
name is somewhat misleading.
AIR COMPRESSOR: A machine that takes energy produced in a coal-burning
power plant 200 miles away and transforms it into compressed air that
travels by hose to a Chicago Pneumatic impact wrench that grips rusty
bolts last over tightened 58 years ago by someone at ARCO, and neatly
rounds off their heads.
   / List of Critical Shop Tools #14
Trouble light; The name says it all. When you use it you are asking for it.
Great for branding flesh, and blinding the user with mis-directed light.
   / List of Critical Shop Tools #15
The ooh-aah tool and dance.
Any tool that gives you a sudden pain in the hand and the subsequent dance with the hurt hand between your knees while chanting ooh-aah or your favorite colorful phrase. It just doesn't get any better than this, unless while doing the popular dance that you trip over the floor jack or some other strategically placed object and hurt yourself some other place.
   / List of Critical Shop Tools #16
Center Punch - device designed to put a small indent close to but not quite on top of where you would like to drill.
   / List of Critical Shop Tools #17
Its actually aptly named cause it has trouble lighting up what one ones to see,and has an uncanny abillity to roll over light down on the ground no matter how one tries to pin it down.
It has the same tendensy to turn away when one uses the hook.
And then there are the air hose and the extension cords who belong in a category all its own,they are "mechanics exersize tools".
They usually resist in providing enough lenght to reach the job at hand by sneaking under something or coil out of their way to snag on something like pails of used oil all the way at the other end,causing one to make multiple trips to correct the situation,thereby exposing themselves to being tripped by the the same cord or hose that somehow managed to throw an other coil.
   / List of Critical Shop Tools #18
G'day hahahaha all very good and i can relate to all of them and also this one
Cold Chisel - the item the operator wraps their hand around in order to steady the hand so as to make the hand easier to hit with the hammer
Jon
   / List of Critical Shop Tools #19
I was about 14 or 15 and working for my grandfather. There was a complete bundle of 2x4s that needed to be cut to length. After "carefully" measuring a master stud. I had whipped through almost the whole bundle.:ashamed:
Grand dad measured 1 of them. The whole bundle was about 1.5" too short. You might say he was a little unhappy. He sat down for a little while and soon figured out how to use them. Sorry but I do not remember what the cure was.
   / List of Critical Shop Tools #20
Arc Welder - A good tool for setting your cloths on fire. In the last 3 or so years I have had that pleasure at least twice. Maybe 3 times. :D
2020 Case 5550 Trident (A56438)
2020 Case 5550...
2016 Ram 4500 Chassis Ambulance (A59230)
2016 Ram 4500...
2013 Ditch Witch XT855 Tracked Loader (A56438)
2013 Ditch Witch...
2023 MERCEDES BENZ SPRINTER 3500 CARGO VAN (A59905)
2023 MERCEDES BENZ...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A56438)
2021 Unverferth...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
