List of Critical Shop Tools
   / List of Critical Shop Tools #1
John (Toronto)
Port Severn, Ontario
Kioti DK40HST
List of Critical Tools and practical description of what they can do for you! (swipped off the internet)
DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL: Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh--!'
SKILL SAW: A portable cutting tool used to make studs too short.
PLIERS: Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW: One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS: Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW: A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER: Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER: A tool used to make hoses too short.
HAMMER: Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE: Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
SON-OF-A-***** TOOL: (A personal favorite!!) Any handy tool that you grab and throw across the garage while yelling 'Son of a *****!' at the top of your lungs. It is also, most often, the next tool that you will need.
   / List of Critical Shop Tools #2
I love it
Bench Grinder - used to sharper soap stone and or carpenters pencils and to alter the bevel angle of cold chizels rendering them useless.
Shop Press - used to permanently jam good sockets into the hole you pressed a bearing out of.
Gear / Bearing puller - used to test theories of ballistics when it pops off and sails over your head as you duck, can also be used to test brain motor reaction times of your body (see also spring compressor)
   / List of Critical Shop Tools #3
Lol. This almost always happens to me. A few months ago. I was pulling out a motor and thought I had all the wires disconnected. I kept going up and up with the engine until it wouldn't go anymore.
I go over to look what it's hanging up on. It's hanging up on around 6 wires I forgot to disconnect.
Chad
   / List of Critical Shop Tools #5
Thank you so much for the post. From where did you compiled all these? Appreciate if you will update the list once in a while.
   / List of Critical Shop Tools #6
Heres another for you
EASY OUT named so as to rub salt in the wound when you realise that you now have a hardend broken off object jammed in that inexcesable hole:D
   / List of Critical Shop Tools #7
Real good.:laughing:
2015 Kia Forte Sedan (A50324)
2015 Kia Forte...
2007 Ford Crown Victoria Sedan (A51694)
2007 Ford Crown...
2013 BOBCAT S630 (A52472)
2013 BOBCAT S630...
Mini Skid Steer Sweeper Attachment (A51573)
Mini Skid Steer...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
