Tire punctures?
/ Tire punctures? #1
NativeSon
Wood County, TX
Kubota M7040SU 2010
Well it's about time to hook up the shredder and get busy. I've got a lot of 1" to 2" Sweet Gum trees that I want to shred. Has anyone done this and had problems with tire punctures from the stubble left in the ground? My M7040 has loaded 6 ply R1"s.
Charlie
/ Tire punctures? #2
I did a bunch last fall, so far no problems & I've been over the same areas twice so far this year - trying to discourage regrowth of some briars, etc.
Nick
/ Tire punctures? #3
We did that last year with our M8540 and R1 tires as well as our L5030 with R4 tires without any tire damage and we cut some quite a bit bigger than that. We cut them pretty low.
/ Tire punctures? #4
It might not work for you, but when I bush hogging, I run low air pressure in my tires. That way if I run over a stob or something it will push the tire in and not penatrate the tire.
/ Tire punctures?
Thanks for the input. I feel more at ease now knocking down those trees. I'm still getting comfortable with the capabilities of the Kubota. So far I have not been disappointed.
Thanks again,:thumbsup:
Charlie
/ Tire punctures? #6
When mowing stuff like this, I keep mt FEL on and fairly low to the ground to keep the trees off my axle/boots/cab etc. and as a feeler for any hidden obstacles. I have also had to use it to back me out of a newly formed washout or two.
I try not to turn any more than necessary as this will expose your boots and let brush in from the sides.
/ Tire punctures?
TripleR, those are good points. Experience pays.
Thanks
Charlie
/ Tire punctures? #8
/ Tire punctures? #9
I still remember the feeling, when i ripped the side out of nearly new Coop tire on truck on a tiny stub.Then I remembered immediately, not taking out any warantty...Pockets inverted? Jy.
2020 ISUZU NRR 4X2 S/A 22FT BOX TRUCK (A59912)
2020 ISUZU NRR 4X2...
Accu-Line 110V Tire Changer (A64556)
Accu-Line 110V...
CASE INTERNATIONAL 39 DISC HARROW (A64278)
CASE INTERNATIONAL...
SARLO (A64557)
SARLO (A64557)
2022 GMC Sierra 2500 HD 4x4 Crew Cab Pickup Truck (A64556)
2022 GMC Sierra...
2021 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2021 CATERPILLAR...
