right front wheel
/ right front wheel #1
Paul Luke
john deere 950
JD 950 The right wheel feels loose and wants to turn in on itself on sharper turns .Is this bearings or could it be something worse.First tractor new here thanks for the help
/ right front wheel #2
I think there was alot of issues with those axles. Jack up the front end and see if you got a lot of play in the assembly. Don.t drive it. People will be along to help you out.
/ right front wheel #4
/ right front wheel #5
Is this MFWD? Just put new bearing on my dad's 1050 with MFWD. Same axel on certain years. Outer bearing completely shot. No damage to the drive gears so it was a simple bearing replacement.
Any damage to the gears will require someone with knowledge to set the backlash.
Brian
/ right front wheel #6
MFWD or not ? Will be good to know. Check for loose wheel and loose tie rod ends.
Glen
What were the front axle issues with the 950?
There were scuffing issues with the 4x00's but hadn't heard about the 950's having issues.
/ right front wheel #7
I could be wrong. I thought 850 and 950 shared the same axle. Guy I worked with had an 850 he had to replace front axle parts two or three different times. His wife used to mow with it and left it in 4wheel all the time and dealer that fixed it said that could be why he had the issues with it. I know he was Hot about the whole deal!
2022 Braxton Creek Freesolo KITCH 18 ft Travel Trailer (A61574)
2022 Braxton Creek...
2008 Toyota Rav4 SUV (A61574)
2008 Toyota Rav4...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
Coats 1550 3D Wheel Balancer Machine (A61573)
Coats 1550 3D...
PRIME 8312 BOX (A63291)
PRIME 8312 BOX...
2014 GMC Sierra 1500 Crew Cab Pickup Truck (A61573)
2014 GMC Sierra...
