anyone here ever build a stand to park a 3 point post hole digger when not in use?
/ anyone here ever build a stand to park a 3 point post hole digger when not in use? #11
Drill a hole in the ground,plant it in it.;)
That is just what we do! Spin the auger into the ground and unhook everything. Its not going to fall over now.:)
/ anyone here ever build a stand to park a 3 point post hole digger when not in use? #12
This is the one I built from some 1.5" scrap pipe and 2" square tubing I had laying around getting rusty doing nothing, so I put it to work. With this setup I am able to back up to it with the tractor, no precision necessary, just get close and I can hook up the PHD myself in just a few minutes with no strain or pain.
Larry
/ anyone here ever build a stand to park a 3 point post hole digger when not in use? #14
Made a dolly for mine. The two post approach means even less lifting when you go to attach it. The top hole will be within a half inch from when you took it off. It also keeps things under control when wheeling it around. This was left over wood, only cost was the castors. Some year I'll put some vertical pieces on the end to hold my other auger.
I also made a small dolly to hold my iMatch, which has to come off to put on the PHD.
Pete
/ anyone here ever build a stand to park a 3 point post hole digger when not in use? #15
Just like beppington, I hang my post hole digger on a heavy chain from the front beam of a pole barn, close to one of the corner posts. Works great, you dont have to build or buy anything.
Except that some of us would have to build the barn first, and that does cost something. :rolleyes:
/ anyone here ever build a stand to park a 3 point post hole digger when not in use? #16
"Except that some of us would have to build the barn first, and that does cost something."
and
"i just hang mine from a tree branch"
Pretty much sums up where I am at this time....
i like the ideas for hanging it indoors. up here in north Idaho, if i were to screw it into the ground and leave it, it would be a rusted mess in no time at all.
all of my equipment is stored under cover. its a pet peeve of mine that if I'm going to spend money for a tool, it is to be stored indoors.
if i don't have room to store it, i wont buy it.
/ anyone here ever build a stand to park a 3 point post hole digger when not in use? #18
I like that thinking, problem is that a barn big enough to hold all my tractors and equipment would cost me well over 100k and I just don't have that kind of money. :(
/ anyone here ever build a stand to park a 3 point post hole digger when not in use? #19
Made this a few years ago out of some scrap wood and wheels from a box store. Not as pretty as some of the others but it works well. It's nice to be able to roll it up to the 3PH.
you must have alot of equipment......send it my way and ill store it for you.
i have buildings enough for all my toys......plus a little room to store some of yours.......maybe ill even let you use it
TULSA WINCH (A60736)
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2003 Freightiner FLD120 (A61307)
2003 Freightiner...
FORD F550 SUPER DUTY SERVICE TRUCK (A52707)
FORD F550 SUPER...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
KJ K2825 28'x25' Metal Workshop (A60463)
KJ K2825 28'x25'...
