Log skidder plate
/ Log skidder plate #1
gregfender
Gold Member
Marion, NC
Kubota L2501 HST
I need some recommendations on a good log skidder plate. I have been using my boom pole, drawbar, and bucket hooks (essentially whatever was handy) to get some of my logs out, but since I want to do some more serious clearing I think I need something specifically designed for what I am doing. While i can probably get my local welder to fabricate something, I was wondering if there are any skidder plates you guys recommend...that don't cost an arm and a leg.
thanks!
/ Log skidder plate #3
na, this is how you skid trees
just kidding. can you make your own??? like in the picture provided above??
i try to minimize logging with a tractor on my place, cause i tend to destroy too many other trees in the process. i'll try to pull them out of the denser areas with logging chains and loader hooks.
/ Log skidder plate
I gotta admit, I do like your set-up!
/ Log skidder plate #6
More on topic, I made my own. A few hours with an angle grinder and a welder and it's done. Works quite well.
Sean
/ Log skidder plate #7
Have you seen a cross draw bar with tractor hook(s) being used ? It is not exactly what you are looking for and it is not nearly as nice as Sean's or the Wallenstien units but they are better than using your fixed draw bar. You can use more than one hook with a couple chokers on each. And you can pick all the logs up with your 3ph to make skidding easier. It is also relatively inexpensive. The draw bar and tractor hooks are available at Tractor Supply. Just thought I would throw this out there.
gg
/ Log skidder plate #8
Okay, someone please enlighten this dimwitted Swede. If dragging a log from above the axle can lead to flip-overs, how is it that the logging winches are safer? they are hanging the logs from way above the draw bar and axle, so what gives? I'm obviously missing part of the equation.
Joe
/ Log skidder plate #9
gg
Looks like a good idea to me, Gordon. I had the "plate" imprinted on my mind when I started, so it stayed there.
The only drawback I could see with the crossbar is the possibility of the log hooking on a stump. Common sense can prevent a lot of that kind of problem, but stuff happens.
I'm giving some serious thought to either adding a hydraulic winch to mine or going full-blown logging winch. I have a bunch of alders to haul out of the ground, and they're in a tough spot to get at.
Sean
/ Log skidder plate #10
Joe
That's a good question, I'll try to respond to it before the paranoia crowd see this thread and the over-the-axle/under-the-axle battle starts.
To my sheltered way of thinking, common sense is the best tool in the box. Most, but not all flip-overs are caused by the log hanging down behind the tractor and hooking into a root, a stump, or something like that. If it's suspended from a point above the axle, the tractor will tend to rotate around the anchor point, which means the front gets very light and often comes off the ground. If you're not quick on the brakes or clutch, it can go right over backwards.
The advantage of the winch or "plate" like I have and the one Wallenstein sells, is that the butt of the log is tucked up behind the plate where it can't hook into something solid and flip the tractor. The only real resistance is friction caused by the weight of the log tip dragging behind the tractor.
Logs should be limbed quite clean to be hauled safely this way, and their weight has to be in safe relation to the tractor. That's where common sense comes into the equation. If the log weighs more than the tractor does and the front end is light on the ground, adding resistance from friction may be enough to get the front wheels off the ground.
After taking all this into consideration, logging is a dangerous business even when you're careful. I've learned to take my time both cutting and hauling, two trips are usually safer than one if in doubt.
A tractor with 3 point winch is a second choice to a dedicated skidder, although they can be safe enough to use if you recognize the dangers.
Sean
/ Log skidder plate #11
I have a winch but built this several years ago...
Lloyd
PS: saw the Wallenstein plate at the Moncton farm show a few weeks ago... it retailed for around $850.
/ Log skidder plate #13
gg
I made one like that, but also welded 4 chain hooks on it as well. It worked quite well for me the first year I did serious logging for the out door wood stove. Then I got the Farmi 601.
I will try to take a picture of it and post it later today....edit: pickies below.. I doubt I had $100 in material in it, (at retail). The key it to get all your log butt ends lined up evenly, drop the lower links, cinch the chains somew3hat snug and raise the TPH just enough to get the buts off the ground.........
First rule of thumb when skidding logs with a tractor: EASY, CHEETA!:thumbsup:
/ Log skidder plate #15
Its easy to build one like the one at Northern for a lot less money.
You can also move trailers with it too.
/ Log skidder plate #17
You don't skid from the top winch point normally, you hook in the slotted bar down low.
Joe
2025 Wolverine PFF1-13-45W Pallet Fork Frame and Hitch Skid Steer Attachment (A60353)
2025 Wolverine...
UNUSED INDUSTRIAS AMERICA F08T-8' LAND LEVELER (A62130)
UNUSED INDUSTRIAS...
2014 Ford Escape SE SUV (A61569)
2014 Ford Escape...
2008 Kenworth W900 Grapple/Storm Truck, VIN # 1NKWX40X68J221827 (A61165)
2008 Kenworth W900...
Yamaha Golf Cart (A57149)
Yamaha Golf Cart...
UNUSED RAYTREE RMSC78 - 78" HYD SOIL CONDITIONER (A62131)
UNUSED RAYTREE...
