Buying 4005 series problem questions
/ Buying 4005 series problem questions #1
Jbodner
John deer 4005
Wondering if any one knows if they heard of any problems with a 2011 4005 series 4 wheel drive 41.8 hp 9 spd standard trans mission I am purchasing the heavy bucket loader and brush hog maybe back hoe if it is a good investment
/ Buying 4005 series problem questions #2
The 4005 tractor is the latest offering in a long-line of JD CUT tractors beginning with the 1050, 1070, 990 tractors.
Basic, no-frills machine.
Long-lived, sturdy, dependable, very fuel efficient and many of them are still doing what they were designed to do after 30 years.
Very few problems that I've seen discussed here on TBN over the years. I owned a JD 970 TLB for just over 4 years and it was a great machine.
The single, most often heard complaint regarding these tractors has been the 2-stage clutch and having the clutch "stick" to the flywheel after the tractor has sat unused for a length of time. Film of rust will form on the clutch plate and the flywheel and the plate won't release. If left for an extended period of time and with a local environment that is warm, humid, etc. chunks of the clutch plate can break off when it does finally free up.
However, this is not a frequent occurrance and can be avoided entirely if you block the clutch pedal to the tractor floor with a piece of 2"x4".
AKfish
/ Buying 4005 series problem questions #3
AKfish
The 790 (990/4005's ittle brother) had a tab welded to the clutch pedal. I used is tab to clamp the clutch down (same as blocking) over the periods of non-use.
I wouldn't be surprised if that 4005 has the same tab.
New/Unused Landhonor Quick Attach Pallet Forks (A61166)
New/Unused...
New/Unused Grapple for CFG Mini Excavator (A61166)
New/Unused Grapple...
UNUSED ATS EPC40 ELEC.PLASMA CUTTER (A62131)
UNUSED ATS EPC40...
Bobcat 873 (A55272)
Bobcat 873 (A55272)
HYD OIL, OIL & USED OIL TANKS (A60429)
HYD OIL, OIL &...
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
