Buying 4005 series problem questions
   / Buying 4005 series problem questions #1
Jbodner
John deer 4005
Wondering if any one knows if they heard of any problems with a 2011 4005 series 4 wheel drive 41.8 hp 9 spd standard trans mission I am purchasing the heavy bucket loader and brush hog maybe back hoe if it is a good investment
   / Buying 4005 series problem questions #2
The 4005 tractor is the latest offering in a long-line of JD CUT tractors beginning with the 1050, 1070, 990 tractors.
Basic, no-frills machine.
Long-lived, sturdy, dependable, very fuel efficient and many of them are still doing what they were designed to do after 30 years.
Very few problems that I've seen discussed here on TBN over the years. I owned a JD 970 TLB for just over 4 years and it was a great machine.
The single, most often heard complaint regarding these tractors has been the 2-stage clutch and having the clutch "stick" to the flywheel after the tractor has sat unused for a length of time. Film of rust will form on the clutch plate and the flywheel and the plate won't release. If left for an extended period of time and with a local environment that is warm, humid, etc. chunks of the clutch plate can break off when it does finally free up.
However, this is not a frequent occurrance and can be avoided entirely if you block the clutch pedal to the tractor floor with a piece of 2"x4".
AKfish
   / Buying 4005 series problem questions #3
AKfish
The 790 (990/4005's ittle brother) had a tab welded to the clutch pedal. I used is tab to clamp the clutch down (same as blocking) over the periods of non-use.
I wouldn't be surprised if that 4005 has the same tab.
UNUSED RAYTREE RMSC78-78" SOIL CONDITIONER (A51248)
UNUSED RAYTREE...
PAIR OF SINGLE AXLE TRAILER FENDERS (A51247)
PAIR OF SINGLE...
2024 Deere 317G (A50123)
2024 Deere 317G...
Tiger Mowers 80in Super Duty Twin Flail Mower Tractor Attachment (A51691)
Tiger Mowers 80in...
2014 DIAMOND C TRAILER MFG. (A50322)
2014 DIAMOND C...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
