Seized Lower Hitch Point
/ Seized Lower Hitch Point
OK everyone...I think I have all the lube I need. I went out and bought:
Blaster SL Silicone Lube
Blaster PB Penetrating Catalyst
Blaster LG White Lithium Grease
A tube of regular white lithium grease
And we also have red grease, WD-40, and 3-in-1 oil...
So, which one should I use again??? :confused:
/ Seized Lower Hitch Point #25
You should *NOT* grease that ball, grease will simply attract and hold dirt, that will make it worse in the long run. Keep it oiled maybe, but no grease, that piece of the hitch spends a lot of time in the dirt...
/ Seized Lower Hitch Point #28
My old BX came with painted ends so thick the eyeballs were impossible.
I took some medium black grit cloth and polished them down. Then, I shot them with white grease and took a long drive extension from the socket set and worked them. Polished some more, worked some more. Finally, they were free enough not to be a pain anymore.
It's common deal Kyle.
Thanks BP. I'll try the grit cloth...:thumbsup:
/ Seized Lower Hitch Point #30
I vote Fluid Film.. Pb Blaster is good, I think Fluid Film is better, I have been very pleased with it. I got hooked with the free sample, and went and ordered some. the stuff really works, stays put, and even smells pretty good. I figured it was hype, have heard about it for years, never tried any.. Well.. now I have..
James K0UA
/ Seized Lower Hitch Point #31
James K0UA
Same story here-Exactly:laughing:
/ Seized Lower Hitch Point #32
Kyle - If you haven't already thought of this yourself, there are three spots on your BX25 to use the Blaster LG White Lithium Grease that you bought. The FEL and BH controls need lubrication and the white lithium grease is perfect for this. Remove each dust cover at the base of the controls and spray the linkages with the grease.
/ Seized Lower Hitch Point #33
I vote for the PB Blaster / Penetrant.
A friend of mine had the exact same problem. We used PB Blaster, stuck a draw bar through the hole and hit the bar with a hammer a few times in every direction possible. Don't know if his had a burr or paint but after the lube and hammer it worked freely as your right one does.
Another reason might be you backed into something hard with that arm which might deform the ball housing enough to make it bind.
Yes, I know. That was the main reason I bought the spray grease.
OK, I think I'll go with Blaster PB. I know I did not back into anything...:thumbsup:
/ Seized Lower Hitch Point #37
Thanks for the reply Roy! It is the implement end eye ball...
Here is a short video:
YouTube - VID00010.MOV
It shows how it can move side to side and down but not up. If you look, the other can move all around. Also, it will move up with some leverage (wrench)...It sure is a nice day...:)
That is how you show your problem!! Great vid
/ Seized Lower Hitch Point #38
I like the Emery Cloth idea. Never seen Fluid Film in this area but PB Blaster is good stuff! Good luck
Your local Deere dealer might have it. That's who sells it around here. Good stuff, Fluid Film!
/ Seized Lower Hitch Point #40
Like Roy wrote, most if not all JD dealers have it on the shelf, or you can look up a dealer on the website. It's good stuff!
2021 BOBCAT T62 R-SERIES SKID STEER (A64279)
2021 BOBCAT T62...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
4' FIELD CULTIVATOR (A63291)
4' FIELD...
2023 Cat 259D3 Skid Steer (A64194)
2023 Cat 259D3...
2021 Bobcat UV34 4x4 Utility Cart (A61572)
2021 Bobcat UV34...
2022 TAKEUCHI TB216 EXCAVATOR (A64279)
2022 TAKEUCHI...
