Loader B2320 Loader Issue?
/ B2320 Loader Issue? #22
Stihl22 said:
Sorry for my english I am a fench canadian from quebec province and i have some problem to express me clearly!
Hey Stihl, if you have questions in French, I am from Quebec also, don't hesitate to PM me if you need info. I have had my B2320 for a couple of years now.
Gyro
/ B2320 Loader Issue? #24
I don't believe that information is accurate. The specs sheet calls them all out precisely the same. The difference is in the loader, as you stated correctly.
Sorry, BP You're right......they are the same .....8.3 gpm (4.7 3ph, 3.6 steering)........:confused3:
/ B2320 Loader Issue? #25
After the dirt hits the back of the bucket it will stop many tractors of all sizes depending on type of dirt of coarse.
that is where good operation of the loader comes in with rolling back the bucket while liftiing and still applying pressure against the pile.
To be digging or surface scimming the top soil off maybe to a five inch depth it is best to go to the back of the bucket dump it on the uncut turf and then go again till you get a full bucket.
/ B2320 Loader Issue? #26
I'm still trying to figure out what tractor to go with and i think the b2320 would def. suit my needs. However one of my primary reasons for getting the tractor is the the FEL for grading and spreading gravel. There is a 1k dif. on the machines but I might have to go with the LA364 loader on the 26.
If I were to buy a new tractor, I would go with 2620... I find myself using the FEL a lot and could definitely use more lift power. For a 1000 bucks it's worth not to have this issue.
/ B2320 Loader Issue? #28
I still pondering.... I agree with you I think I just dont want to go overkill. I suppose when it comes to loader lift you cant ever have enough.... :thumbsup:
I wouldnt spend that money for a a few horses under the hood...
/ B2320 Loader Issue? #29
Hey boys,
I was thinking about reset the relief valfe a littel bit higer at about 2200 psi insted of 2000psi to get more lift capacity. But one of my friend said to me that the most easy ting to do is to buy bigger cylinder. What do you tink if i buy cilynder or a la364 spec to go on the la 304. Cause i compare the two loader last week and the only thing that change at my eyes was the bucket (2 inch wider) and the cilynder.
/ B2320 Loader Issue? #30
I bought a B2320 with 364 FEL & from now messing with it for 31 hours think that more HP wouldn't do me any good. It will surely lift a full bucket of dirt but to grab one my limits seem to be what I'm digging, angle available, my skill level & tractor weight. Plenty of grunt, small machine. I'm impressed so far.
Dexter trailer axles (A61567)
Dexter trailer...
6' Disc (A62613)
6' Disc (A62613)
3pt Heavy Duty Carry-All, 3'x6' Platform (A62679)
3pt Heavy Duty...
Speed Trailer (A64194)
2002 Ford F-550 Dump Truck, VIN # 1FDAF56F32EC86522 (A65563)
2002 Ford F-550...
24 Gauge R Panels (A65640)
24 Gauge R Panels...
