Oil Oil Oil
/ Oil Oil Oil #1
stumpfinder
Never would have thought trying to get some **** hydraulic fluid would take up so much of my life.
I need GL-4 and can't find anything that says on any container of fluid at
Tractor Supply (travelers and one other)
Wal-Mart (rotella and super tech)
Auto Zone (costal)
Oriellys (home brand)
Where are you guys buying this? I understand GL 5 is newer and in some cases it protects yellow metals and all that crap.
This tractor is still under warranty and I just need some GL-4 flat out, please give me a STORE that sells GL-4 universal hydraulic fluids.
Or do I need to go to the dealer?
j
/ Oil Oil Oil #2
I could very easily be wrong and probably am but isn't GL-4 and Gl-5 gear oil (90w, 85w-140 etc.) and not hydraulic fluid ?
/ Oil Oil Oil #3
I just used Traveler Premium UTF. Works good for me, says it meets the waranty requirements for Mahindra on the back.
/ Oil Oil Oil #4
Auto Zone (costal)
j[/QUOT
Walmart do carry some hydraulic fluid, at least where i live, might look there.
/ Oil Oil Oil #6
Auto Zone (costal)
j
napa house brand multi rated GL-4/GL-5 gear oil
advance auto has "coastal" brand multii rated GL-3/GL-4/GL-5 gear oil
link to my thread from 2009
http://www.tractorbynet.com/forums/mahindra-owning-operating/143581-4110-fluids.html#post1660737
/ Oil Oil Oil #7
As for manual transmission gearing, how they are set up and the service factor dictates the use of many different oils. OEMs sometimes recommend automatic transmission fluid such as MERCON or ATF+4, specialty lubes such as synchromesh fluids and API GL-4, 75W-90 viscosity gear lube. The difference in GL-4 and GL-5 is that GL-4 gear lubes have half the extreme pressure additives of GL-5. Because the gear types in manual transmissions do not necessitate the use of GL-5 gear lube, GL-4 is the correct recommendation called for by most OEM’s when gear lube is required.
In all cases synthetic oils and gear lubes provide better fluidity at cold temperatures and higher oxidation resistance at elevated temperatures. Synthetics also provide longer service intervals than petroleum lubes. By recommending the correct synthetic lube for each application, customers will see the difference and feel comfortable about leaving their vehicle with you for future service
http://www.lubrizol.com/DrivelineAdditives/AutomotiveGearOil/GL5.html
Answers.com - Whats the difference between gl4 and gl5 gear oils
Amazon.com: CRC SL24229 API/GL-4 Multi-Purpose Gear Oil, 32 Fl Oz: Automotive
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A64278)
KNOW BEFORE YOU...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
2022 JOHN DEERE 17G EXCAVATOR (A63276)
2022 JOHN DEERE...
HARDEE 148 ROTARY MOWER, 3PT (A64278)
HARDEE 148 ROTARY...
2016 Freightliner M2 106 S/A Day Cab Truck Tractor (A64194)
2016 Freightliner...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
