2017 Emax 25 HST s.. Just bought need help Please
   / 2017 Emax 25 HST s.. Just bought need help Please #1
Tractordood
2017 mahindra emax 25 hst s
I just bought a 2017 emax 25 hst s. I've tried searching and searching through here. I dont know what goes where. There's no fluid level showing on the sight glass so it needs fluid. The book says GL-4 80W, but I seen a guy on here using (Traveller universal trans/hydrauic fluid)..Is this right? I found GL-5 80w, will this work? Does this thing have separate hydraulic fluid? Or is it all shared from the transmission fill? Thanks
   / 2017 Emax 25 HST s.. Just bought need help Please #2
Hello Tractordood, My book also says GL-4 80W(gear oil) on page 54. On page 55 it says Mahindra Universal Tractor Fluid. I don't know if that is one in the same. I'm sure my dealer is using hydraulic fluid as I had mine changed at the 50 hour oil change. I am taking it in hopefully Monday and I will ask for specifics. I understand if gear oil is changed to hydraulic or vice-versa, the system must be thoroughly drained as they are not compatible.
Everything runs off the same hydraulic pump.
As you read the Operator's Manual, you'll notice some discrepancies and miss-prints! :unsure:
   / 2017 Emax 25 HST s.. Just bought need help Please #3
To address the GL-4 vs. GL5, I know marine use recommends GL-4 as does the old Wheel Horse garden tractors. It's been said GL-4 is compatible with brass bushings etc, so I have been using GL-4 80/90 in my 3 Wheel Horse trannies for years.
Yeah there's some discrepancies in there. I used the trans/hydraulic fluid, we'll see what happens. I did overfill it though, like to the fill spout. Probably drain some off tomorrow
(UNUSED) CF POWERLINE 5' ROTARY MOWER (A52708)
(UNUSED) CF...
20' CONTAINER (A58374)
2013 JOHN DEERE 650K LGP CRAWLER DOZER (A52709)
2013 JOHN DEERE...
Deere 310L (A53317)
Deere 310L (A53317)
LOT: Kimball Midwest 4-Drawer Hardware Cabinet w/Contents & Stand (A59076)
LOT: Kimball...
296385 (A57192)
296385 (A57192)
