Fixing a 4-in-1 bucket
/ Fixing a 4-in-1 bucket #1
gregfender
Gold Member
Marion, NC
Kubota L2501 HST
I've had my new-to-me 1070 for a day...and no, I haven't broken anything...yet. However, the back (blade) half of the bucket is a little bent...actually warped may be a better word. There is a gap of about 2inches toward the center when the clamshell is closed. (see attached)
Any suggestions on how to correct this? I was thinking perhaps taking it to a friend of mine and having a piece welded on or even having the blade straightened. Has anyone had a similar issue? The bucket is still useful but if I'm moving small material I might be loosing some.
/ Fixing a 4-in-1 bucket #2
I'd guess the previous owner lifted a bit more then that bucket was designed to handle.
That wear bar across the blade half is going to be an SOB to pull straight, I think. But if you can disassemble the front section, you might be able to use a come-along on it. You'd have to drill a hole through the center of the wear bar for a bolt or clevis (some for the come along to hook on to). Don't depend on a clamp unless your life insurance is paid up to date.
Welding another wear bar underneath the blade half would probably be easier.
Shouldn't that 4 in 1 have a hydraulic cylinder on it (to open and close it), or am I missing something?
/ Fixing a 4-in-1 bucket #3
This is a double post of the problem.
/ Fixing a 4-in-1 bucket #4
Wow, GREG, that looks like the same 4n1 that I have, a WRLong HJ60.
Mine was originally for a JD 460 loader, too. These are very light duty to
keep weight down.
Anyway, mine was bent, too, but not as bad. I used a 20T jack and
I-beam to bend it back. Here is the thread:
http://www.tractorbynet.com/forums/customization/133597-adapting-wrlong-4-1-bucket.html
keep weight down.
Thank...I might give that a whirl. I'd rather not have to try and replace a whole bucket or add too much to it.
GENERAC MOBILE PRODUCTS MAGNUM LIGHT/WATER PLANT (A67714)
GENERAC MOBILE...
IRON RHINO IR1000 Mini Skid Steer (A68134)
IRON RHINO IR1000...
2018 Bigfoot Equipment Trailer (A64911)
2018 Bigfoot...
2023 Unused Hustler LM260 Swiftblade Tractor Loader Attachment (A66734)
2023 Unused...
(2) Bean Royal Sprayers (A64912)
(2) Bean Royal...
2016 Ford F-150 XLT (A64911)
2016 Ford F-150...
