Hyd thumb and 12" bucket--Compatable???
/ Hyd thumb and 12" bucket--Compatable??? #1
Carl Bert
Rockland county, New York
Kubota B26, John deere X595
I was recently told that my Hydraulic thumb may not be compatable with a 12" bucket. The 12" bucket is too small for the thumb and does not line up correctly. Possible damage can happen to the thumb or even the dipper arm.
I know nothing about this nor did my dealer mention anything about it when selling it to me.
The only thing that I can imagine being a problem is how the thumb and the buckets teeth meet. Maybe the thumb is supposed to fall inside the bucket, as I would imagine it would do on a larger bucket.
Here are some pictures:
/ Hyd thumb and 12" bucket--Compatable??? #3
I'm no expert mind you, but that looks like it should work just fine. The teeth don't appear to clash in your photo's. Looks like it will work rather well actually.
:thumbsup:
My Woods is only a Mechanical thumb and it works well with the little bucket I bought to go along with the 16 inch one.
/ Hyd thumb and 12" bucket--Compatable??? #4
Looks good to me also. Guess it is more what YOU like and what works for you. How often do you use it?
Hardly ever. I just want to make sure that when I do use it, I won't damage anything. Thanks
/ Hyd thumb and 12" bucket--Compatable??? #6
Carl,
I have a BH90 with the mechanical thumb and 12" bucket, the only problem I encounter is when ditching deep the thumb mounts are wider than the bucket so in hard ground you have to widen the ditch to get deeper, the only thing that I can see this will damage is premature wear to the mounting ears that the thumb shaft goes into from contact with the sides of the ditch.
/ Hyd thumb and 12" bucket--Compatable??? #7
There is the potential for the bucket to over ride the thumb cyl, or vice verse. A relief could be installed to relieve the thumb or bucket if there is a possibility of damage. Depending on the lever principle, and the forces applied, the pressure in one of the cyl could be elevated beyond the limits of the cyl or hose/fittings.
Which is the stronger of the two? Can you push the bucket with the thumb?
Does your BH valve have work port reliefs?
2019 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
2015 International WorkStar 7500 T/A Forestry Grapple Truck (A64556)
2015 International...
KUBOTA SVL95-2S (INOPERABLE) (A65643)
KUBOTA SVL95-2S...
2016 KENWORTH T800 TRI-AXLE (A65643)
2016 KENWORTH T800...
Bush Hog 285 3-Pt Rotary Cutting Mower (A66285)
Bush Hog 285 3-Pt...
213324 (A64279)
213324 (A64279)
