need help fixin' vehicle
/ need help fixin' vehicle #1
rockinmywaypa
under the elephant\'s tail [ ontario can.]
john deere 3130, universal case 970 and a IH 1086
My son has a 98 dodge dakota, recently it stopped charging and he barely made it home in the partial darkness. I checked the difference between battery voltages when shut off and when running and lo and behold it was charging again. He drives it to school and halfway there it stops charging. Back home and testing and it starts charging again. Right now I'm not sure what to start replacing, hopefully it's not the wiring which could be a real pain tracking but what would be the order of cheapest probable cause to most expensive hopefully last resort to change. Thanks for any help.
/ need help fixin' vehicle #2
How old is the battery? Are the terminals clean and tight? Is the negative ground on the frame clean and tight? Are the connections on the alternator clean and tight? Is the alternator belt in good shape, or loose and slipping? Most charging problems are caused by these simple reasons, if these don't pan out check the voltage regulator...not sure if it is built into the alternator or not. May be a failing alternator...and just curious, how far is the commute to school? How far does the truck go before it acts up? Hope this helps.
/ need help fixin' vehicle #3
Not saying it cant happen, BUT I have NEVER seen an alternator charge and then quit and then charge again. It either works or it dont. So It doesnt sound like that is the issue to me.
I would start by assuring that ALL the batter and alternator connections are tight AND clean. Also make sure the belt that drives the alternator is tight as well.
Given the information you supplied us with, My money is on it being a loose/corroded connection somewhere.
/ need help fixin' vehicle #4
My dad had a starting/charging problem on his '77 F100, it drove him nuts...and it was a poor connection on the negative cable where it connected to the frame...loose and corroded.
You guys are quick, The connections on the battery are clean and tight, I don't know the age of the battery but it holds up for however long the truck is parked, sometimes a couple weeks this winter and still started right up despite Canadian low temperatures. The belt looks decent and is tightened with a spring loaded idler on a serpentine belt so I can't tighten it any more. I think the regulator is built into the alternator, There is fuse or solinoid or relay thingy near the fuse box that has a cloudy look but looks ok inside the glass case. The school commute is about ten miles or a fifteen minute drive whereas he got about halfway there when he noticed that the red light was on on the dash to let him know it wasn't charging. I will definetly check out the neg. cable to the frame and maybe remove it to make sure it hasn't built up with rust between the layers.
/ need help fixin' vehicle #6
Shoot, there go most of our easy fix solutions....
/ need help fixin' vehicle #8
Well if you are sure all the connections are clean and tight, including the ground to the frame that you said you would check on...
...And if you are sure the battery is good (which it sounds like)
...And if it has an internal regulator in the alternator
...Just spend the $100 or so and replace the alternator. That is the only thing it can be at this time other than a faulty guage or sending wire to the guage. It could be that it is charging just fine but a loose connection to the guage could cause these problems.
But I'd probabally start with the alternator. Especially if higher mileage, given that it is almost 15 years old.
/ need help fixin' vehicle #9
"Sending wire to the gauge"...from what I interpret the truck has a warning light not a real ammeter. I hate working on vehicles that don't have real gauges just stupid idiot lights. An ammeter gauge would likely tell if things were charging or not.
/ need help fixin' vehicle #10
+1 for what LD1 said. If the regulator is internal to the alternator, then just replace the unit. Depending on your local auto parts store, some offer free diagnostics if you bring the thing into them. So you could just pull it out take it to the store and have them test it. That way you don't waste the money on a new one.
But I would be leaning towards just replacing it do to its age and mileage.
/ need help fixin' vehicle #11
Sounds like alternator- when they start to go lights dim, sometimes a high pitch whine. It might take them a month to go once they start - car starts fine then lights dim , battery dead when go to restart. Next day the battery recovers a little and car starts. then battery is finally really dead. Fow a while it is charging a little but then your car starts demanding more juice than the alternator can produce, so it takes it directly from the battery - killing the batter. Get a rebuilt alternator with at least a 6 mo guarantee. If it lasts that long - it will last forever. Skip the one month guarantee alternators because they could be junk with cosmetic cleaning. Good luck -- not so hard to change yourselves, but get that belt really tight or it won't charge. Don't mix the wires on the alternator when switching - you can burn up your new alternator before it is all the way in!
good luck
/ need help fixin' vehicle #12
After checking terminals, I'd put a charger on overnight.....next day, then test battery with one of these.....
100 Amp 6 Volt/12 Volt Battery Load Tester
It will induce a 100 amp load (simulating cranking on the engine)....if OK, then start-up truck and witness charging voltage......if it fails (less than 12.6 volts) change the alternator (it should read 13.5-14 volts)......done.......:thumbsup:
This tester is better than just a multimeter with the 100 amp load switch.....
/ need help fixin' vehicle #13
I have a Dodge pickup. It's alternator was intermittent. I think the brushes were so worn they were only making contact part of the time. Sometimes when the alternator would quit, I could slow down the engine's RPM or turn it off and restart to get the alternator to work. When the alternator was failing, I could even hear a high-pitched buzzing through the radio.
I replaced the Alternator with one from AutoZone and have not had a problem since.
/ need help fixin' vehicle #14
Yep! That's a common problem with alternators with lots of miles on them.
Thanks for all advice, I worked all night and just got home so I haven't been able to check anything out yet. It does have an ammeter to tell you if it's charging but obviosly it wasn't watched that close. It does have a lot of kilometers on it so monday morning I'll pick up an alternator on the way home from work and see if it makes a difference. Thanks again all of you.
/ need help fixin' vehicle #16
Glad we could assist, please keep us informed so we will know what was going on...good luck !!
/ need help fixin' vehicle #17
+1. The ground is too often overlooked.
I think car part stores have a way to test an alternator - I am sure they can test starter and a battery. If nothing works and you are ready to swap the alternator, I would have it tested first - typically it is free.
I also am guilty of throwing parts at a problem instead of proper troubleshooting.:)
/ need help fixin' vehicle #18
Dodges are kinda funny about a few things. Make sure he is not turning on the headlights before starting the vehicle. A friend of mine was having the same problem you describe, took it to the dealer numerous times to no avail. Found out by accident turning on the headlights before starting the truck causes the charging system not to operate properly - a computer glich. Went back to starting the truck, then turning on lights - no more problems.
/ need help fixin' vehicle #19
Interesting to learn that...we used to have an Olds 98 with the auto-on headlights that came on when it was dark, as you started it...not DRL's, but the main headlights. I told my brother in law about it, he was a GM electrical engineer, and he told me that when the headlights came on as you started the engine, it helped warm the battery...??!! I was asking him in the context that maybe we should turn off the auto-on feature to have more juice available for the starter motor in really cold weather.
Does that make any sense to you guys?
/ need help fixin' vehicle #20
Not a lick of sense to me.:rolleyes: What would a few amps of headlight current do to warm a battery that a few hundred amps of starting current would not? Maybe your BIL is the GM engineer who designed GM's running lights on their pickups and Suburbans. You know, the ones running up and down the road with only one light working.:laughing:
2018 Tycrop Vector Belt 22ft. VB-16H Portable Sand Belt Conveyor (A64194)
2018 Tycrop Vector...
2002 Ditch Witch 1230H Walk-Behind Trencher (A64553)
2002 Ditch Witch...
2015 Nissan Leaf Hatchback (A64557)
2015 Nissan Leaf...
2021 Bobcat T62 Compact Track Loader Skid Steer (A64553)
2021 Bobcat T62...
2018 CATERPILLAR 307E2 EXCAVATOR (A65053)
2018 CATERPILLAR...
2021 TORO MRTX2500 68138HD STAND ON CONCRETE BUGGY (A63276)
2021 TORO MRTX2500...
