First time drilling post holes
/ First time drilling post holes #1
SandyTX
CenTX (Bell Co.)
JD 4300
Picked up a Auger at TSC last weekend with a 9" auger bit.
I dug 4-5 holes in the yard ( to plant some trees) and it worked great.
I then took it out to my farm and dug 3-4 more holes which went ok.
So I then went to the gate to dig 2 holes for the new poles for the gate.
I got the first one down almost 4 ft and went to pull it back out and bamo (stuck like chuck). No lift at all. After 2 hours of digging it out; I had to spin the auger by hand (after i disconnected the PTO to remove it).
Now I thought; I'll never do that again; I'll take smaller bites each time.
Well you see where this is going....
Next hole; I do about 4-5 bites and its going great and the depth is good. I'll just do one more pass to clear the dirt and BAM! stuck again :( .
Well after 2 more hours of digging I managed to digg about 5 post holes with the tractor in 6 hours. Live and learn. But I can tell you I'm not letting it happen again (on purpose at least). It was a nice day out (60s) and cloudy so all was not lost. I did move about 1/2 ton of soil to finish up some back stops on the shooting range.
All in all it was good; no one got hurt and I got in some great seat time.
/ First time drilling post holes #2
That is an education that many of us have, as well. :D :D
Good to pass it on for others to learn from too. :)
/ First time drilling post holes #3
I have not gotten the auger stuck.....yet anyway. I am still learning how to get the hole plumb. I have not gotten the hand of digging and pulling up to keep the hole perpendicular to the ground.
/ First time drilling post holes #4
When I go to auger holes, I always take my 24" pipe wrench with me. Many of times I have had my auger get stuck in tree roots. I shut it down and reverse the auger out of the hole with the pipe wrench. Much easier than digging. After all that is why I bought the auger was to cut down on digging with a shovel and clam shells.
/ First time drilling post holes #5
Ive been using my auger for years..have dug many holes. Luckily we have decomposed granite here, so there is not too much tendency to get stuck.
But i still continually raise and lower the POD as I'm digging to keep the hole clean. I never let it just plow on down.
i was digging some holes at a friends place, and it hit clay and dove into the ground. after unhooking and chaining it to the loader, i had to use a pipe wrench to rotate it.
I SURE wish the pto would run in reverse,,,, is that too much to ask for in the 21st century :laughing: :thumbsup: :D
/ First time drilling post holes #6
Standard Operating Procedure when using an auger. You usually only have to turn it backwards a half turn or so, and it will pull free.
/ First time drilling post holes #8
SandyTX:
How I can empathize with your PHD experience, which is why I got rid of my PHD...more trouble than it was worth.
/ First time drilling post holes #9
Right on guys, use the pipe wrench and turn the PTO shaft to reverse the auger. NO need to unhook from the tractor, unless for some reason your PTO shaft doesnt free wheel in neutral. Dont try to turn the auger itself unless you want a hernia, turn the pto shaft to reverse the auger. It takes several rounds on the shaft to get one turn on the auger, but usually after a turn or two it will come out if you kept the hole cleaned out as you went down. NO way would I try to dig one out, way too much work. Just back it out just like you would remove a screw( a very big screw) from a board.
/ First time drilling post holes #10
SandyTX:
You'd rather dig post holes by hand than back the auger out ever once in a great while? You have better shoulders than me. :D
/ First time drilling post holes #11
I've watched my Dad dig thousands of holes and cant remember ever being stuck. We build miles of fence every year and he drills holes with a 801 Ford. He starts and goes all the way to the bottom without stopping, usually about full throttle and pulls it up while spinning. Works like a charm.
/ First time drilling post holes #12
What engine speed are you trying to dig holes ?
At near idle or rated pto speed? Idle or near idle is best.
/ First time drilling post holes #13
Agreed! What is your PTO HP?
/ First time drilling post holes #14
I don’t think the RPMs have much to do with it. It’s all about the “feed” rate. If you let the auger get a bite and screw itself in the dirt, you’re stuck. At high RPMs it just happens faster, but it still happens. The operator needs to feed the auger into the dirt at a rate that allows it to dig, but not just let it drop freely. It just takes a little practice.
/ First time drilling post holes #15
Well that makes at least three of us:thumbsup:
/ First time drilling post holes #16
I have also used a two man, gas powered post hole auger, and you quickly learn to lift it up and down, to clear the hole, as you drill down!
Next time you see a line crew installing utility poles, watch them go down 4/5 feet with a 24" auger. Or grab your Harbor Freight cordless and ( try to!) drill a 1/2" hole in a piece of oak. It's all about applied power.
/ First time drilling post holes #18
I imagine around 40 04 45 hp. Diesel with 10 speed select-o-speed.
-I didn't mean YOUR tractor, ole farmerbuck, I meant the OP!
I see now it is a JD 4300, with 27 PTO HP. That should be enough to handle a 9" auger, but I'll defer to your experience; you have drilled a lot more holes in the planet than me:thumbsup:
I was revving the RPM to the rated 540 PTO for the auger but I can see now its more of a feel when drilling holes.
I'll try the pipe wrench next time. Thanks for the information everyone; I guess it happens even to the best of us (though I'm far from the best).
/ First time drilling post holes #20
Have said it before like others.Check your gear box oil(80/90).Every TSC PHD and lots of others I have seen come dry shipped.
Keep playing "SAFE" ! :thumbsup:
Boone
2016 Jeep Compass SUV (A61574)
2016 Jeep Compass...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
Bobcat Skidsteer (A60352)
Bobcat Skidsteer...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2016 Peterbilt 320 EZ Pack 40yd Front Loader Garbage Truck (A61573)
2016 Peterbilt 320...
