Case 480D backhoe Alternator Belt Replacement
/ Case 480D backhoe Alternator Belt Replacement #1
bill Treff
Case 480D
Does anyone know whether or not you have to remove the from hydraulic pump to replace the alternator belt on a Case 480D backhoe loader. The hydraulic pump is attached to the front of the crankshaft after the lower pulley. It appear that the pump has to be removed to replace the alternator belt. Is there an alternative? Thanks, Bill Treff
/ Case 480D backhoe Alternator Belt Replacement #2
G'day most of the ones i have worked on you only have to undo the drive on the lower pulley and you should be able to push it back towards the pump and you can wriggle the belt through you may have to turn the coupling through 90o to get it through.
Jon
/ Case 480D backhoe Alternator Belt Replacement #3
Yes there is
/ Case 480D backhoe Alternator Belt Replacement #5
When the belt broke on my 480 I replaced the belt with one of those link belts. It was a little pricey but has held up great and I didn't need to remove the hydraulic pump.
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
2017 Mercury SeaPro Outboard Boat Motor (A61574)
2017 Mercury...
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Ford Explorer AWD SUV (A61569)
2015 Ford Explorer...
