Snowblower chute rotator
/ Snowblower chute rotator
Good job on that Saskman.:thumbsup:
Here's my version I put together close to 20 years ago using a surplus cylinder and steel and cables I had lying around. The only parts I had to buy were the 2 pulleys and the hoses.
It has always worked great. On my previous tractor, I could rotate it well over 210*, but I had to reduce the rotation for the B7800 or the chute would hit the cab when the blower was raised. I did that by changing the pulley spacing.
The cable is a little sloppy now since I bent the cross bar the pulleys are mounted on by trying to rotate the chute when it was frozen up.:( (Snow had melted, water ran down to base of chute and froze chute to blower body.)
Thanks, if i had more time i would have built my own but i just cant find the time to get alot of extra stuff done some days. I take pride in modifying stuff but some times a person just dont get the time. I like your set up too. Like i said, for the 100 bucks it cost, im happy with the results.
/ Snowblower chute rotator #23
THIS IS MY SET UP AND IT COST WAS A LITTLE UNDER $200
Well i didnt get a part number. The dealer was closed for some reason. Ill try and find some thing for you soon.
/ Snowblower chute rotator #25
Hey JWatt.... electric right? Looks great! Had a question regarding the shaft connection to the 'worm drive' of the chute. Did you use bushings or sleeve to fit the shaft(s) for the motor and the receiving part? Did you bore your own to fit? I've been having a hard time trying to find something that would marry the two together.
Otherwise I've got all the parts but that. I didn't even think about the chute deflector attachment. Cool idea.
/ Snowblower chute rotator #26
I used a piece of the hand crank that slides into the larger piece of the crank.I just cut off a small piece,drilled a small hole in both the shaft and small piece and put a nut,bolt and lock washer.
/ Snowblower chute rotator #27
i have a FarmKing snowblower and its a simple cable pull system. has been working for 4-5 seasons now, and never freezes up. here are a few pics. its a double action 8" hydraulic cylinder. I set it to overshoot on one side, nearly hitting the tractor. this is to clear a vulnerable part of one of my buildings. you can set the cables to limit the stop at whatever angle you wish.
Winco 12T Fertilizer Tender Box (A66408)
Winco 12T...
6ft Teakwood Cowboy (A65583)
6ft Teakwood...
1993 GMC Sierra Pickup Truck, VIN # 2GTEK19K7P1534489 (A65563)
1993 GMC Sierra...
2012 Ford F350 Truck (A62679)
2012 Ford F350...
Kivel Skid Steer Forks (A65640)
Kivel Skid Steer...
New/Unused CFG Industrial NT18K Mini Excavator (A65583)
New/Unused CFG...
