For ANYONE who has installed the WRLONG 3rd Function valve KIT
   / For ANYONE who has installed the WRLONG 3rd Function valve KIT #11
The only thing I can add to this thread is NOT to use teflon tape on any part of a hydraulic system. If I remember correctly, if the tape breaks off it can cause problems with the valves. Pipe dope is ok. Bill C
That is not really an absolute but you are correct that one needs to be careful and not get the tape into the system. Just don't put the tape at the tip of the fitting. I start a few threads back and have never had trouble.
What's the 'recommended' paste (for lack of better word) that I should use for connecting the fittings?
   / For ANYONE who has installed the WRLONG 3rd Function valve KIT #13
Search the term "PTFE", it's a hotly debated subject:thumbsup:
   / For ANYONE who has installed the WRLONG 3rd Function valve KIT #15
I have the WR Long system (4 in 1 bucket) on my Kioti CK30. I had my dealer (Upper Valley Tractor in Enfield, NH) install it while I they were doing the 1st service. I didn't want to mess with my warranty or create any possible issues by installing it myself.
The WR Long system is AMAZING! I was able to pick up a 7.5 Meyer's plow this winter on Craigslist for only $400. After I replaced one of the angle cyclinders, I was able to locate the quick attach JIC connectors, and now use the toggle switch to angle the plow!
Once you get the system installed on the tractor, you will wonder how you lived without it.
Good luck,
marc
Kubota SVL75-2 (A57148)
Kubota SVL75-2...
(APPROX. 20) 4' X...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
Kubota BX25D (A53317)
SHOP TOOLS (A58214)
SHOP TOOLS (A58214)
