Anyone adjusted a shuttle shift??
/ Anyone adjusted a shuttle shift?? #1
BobG_in_VA
Central VA, USA
Mahindra 6000 MWFD, 2 1950's Farmalls, 1974 Farmall 140, 1967 Mf 135Delux
First things first...I've got a '02 6000 4WD...Have noticed lately that the shuttle shifter has a tad of "slop" in it (going from forward to reverse)..I noted last week that when I shifted from forward to reverse and let out the clutch it had not engaged (didn't have any grinding). I went back to forward and it took...really pulled it down this time and it engaged in reverse...anyone adjusted their 00 series shuttles?? Thanks BobG in VA
/ Anyone adjusted a shuttle shift?? #2
I have the 5500 4x4, the only problem I had was the handle on the linkage shaft for the forward and reverse was begining to have play in it. I removed the handle and drilled and taped for two set screws, so far so good.
Good thought! I'll check it.. BobG
2006 Peterbilt 379 T/A Sleeper Cab Truck Tractor (A64194)
2006 Peterbilt 379...
2017 HAMM H12i PADFOOT ROLLER (A65053)
2017 HAMM H12i...
Bobcat 60� Rotary Cutter (A64047)
Bobcat 60�...
2022 EZ-GO ELITE...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
Lot 602 (A62613)
Lot 602 (A62613)
