Diesel garden tractor pulling
/ Diesel garden tractor pulling #61
hi yes i do what u do but i run a 3cy yanmar diesel with nos propane and water and i have a 2inc turbo
/ Diesel garden tractor pulling #62
I am building a diesel puller right now and was wondering how to make the kill switch for the rear of the machine. i think a guillotine shut off would work best but i am unsure how to make it any pics you guys have would be great.
/ Diesel garden tractor pulling #63
I use a trailer brake break away switch hooked in line with my fuel shut off solenoid
/ Diesel garden tractor pulling #64
i dont have a fuel pump it is gravity feed from the tank to the injection pump.
Adapt one of these to front of your turbo inlet. Spring load it. Run a choke cable with a ring pull on it from the rear up to it and run it thru the hole.
If you ever put an electric pump on you will have to add a power disconnect to the same ring. You will eventually need an electric pump that pushes 40psi when you make power so be prepared. Last thing you want to do is stick a plunger. Put an easy to get to shut-off valve on the fuel line as close to the injection pump as you can also.
McMaster-Carr
/ Diesel garden tractor pulling #66
thanks i think i will build one though. i am not workin so money is tight but i have the material to build one thanks for the link though.
/ Diesel garden tractor pulling #67
true pulling tractors are totaly cool. when i was in the army we would spike diesel fuel with gasoline in a 5 ton wrecker. we would blow the 2 1/2 tons in the weeds . also we cranked the tire pressure up to 100-110. my o my i beleave i remember that far back.
/ Diesel garden tractor pulling #68
Here are a few pictures of my puller that im workin on. hope you enjoy.
/ Diesel garden tractor pulling #70
i used to pull diesel pickup class and the hobby has gotten so competative and expensive i cannot afford to play anymore so since im a hardcore diesel fan i am going to build one of these tractors and return to the track i have found a d600 series kubota that i will b purchasing any tips or tricks would b gladly appreciated as far as drive line gearing performance parts for the kubota rods cams pistons etc. also bigkrank wat do u charge to build a cub rearend for a customer prolly need just a mild one to start out with but im not for certain and also how are u connecting the kubota to the cub transaxle thanks for any info one might have
/ Diesel garden tractor pulling #71
i am pulling a cub cadet stock class i got me a super stock pulling cub but I need to get me sum alcohal for it to burn
/ Diesel garden tractor pulling #72
Just found this site and really like your Oliver. Could you please tell me more about the front grill - did you fabricate it, what material, can I buy a similar grill, etc.
Thank you.
/ Diesel garden tractor pulling #73
:newhere:im from butler pa and really wana get into this sport im 16 and i own an old case 446 that i want to build into a pulling tractor cuz the motor is cunk in it do you know anyone from around here that could help me thanks:thumbsup:
/ Diesel garden tractor pulling #75
Newbee in the diesel world but what gears are best in the original transmission for a mildly upgraded kubota 3cyl diesel
/ Diesel garden tractor pulling #76
It has been several years since this thread was started. I have some questions since it has been several years since I have followed gt pulling:
1. Has popularity in the diesel class grown?
2. Are they allowing turbos in any of the non-diesel classes?
3. What about any type of fuel injection?
I am kind of curious in what big rule changes or new classes have come up over the last several years. I'm interested in getting into pulling.
Ed
/ Diesel garden tractor pulling #77
I dont pull, but spectate and always think about it.
Around here the answers are:
No (typically only 2 brothers that pull diesels and they mix in with a class of other v twin stuff)
No
No
Landhonor BH-12-72D Backhoe Skid Steer Mount (A62679)
Landhonor...
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2016 FREIGHTLINER CL120 GLIDER 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
16ft. Aluminum Extension Ladder (A65640)
16ft. Aluminum...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
