Seat for a 955
/ Seat for a 955 #1
JD955SC
JD 955
What the title says. I need a replacement and seats at Tractor Supply are priced outrageously ($100 for a seat, really?)...I'd like something that's affordable and similar to what's on the tractor now (black midback seat)
/ Seat for a 955 #2
Sorry but $100 is cheap for a seat. TSC has the cheapest I've found locally. You can check eBay but Unfortunately they typically go up from there once you get into the suspension seats. Good luck with your search.
/ Seat for a 955
That's just ridiculous. I could understand if it was for the bracket/suspension or whatnot, but for the seat alone...that's stupid money.
Guess it's kinda like my stupid truck seat...little cheap plastic part down in the seat rail that locks the fore/aft slide movement broke, only way to fix it is to by a $200 replacement entire seat rail, that, oh by the way, is virtually guaranteed to break again in the future.
/ Seat for a 955 #4
It is crazy. Suspension will put you in the $250+ range.
/ Seat for a 955 #6
That's just ridiculous...
So is $45 for an exhaust pipe. $700 for a plastic hood. $450 for a cheap flimsy grille. $400 for the clutch & steel pack for the PTO clutch. $100 for hood hinges..... I could go on and on. Virtually everything you will ever buy for these tractors is rediculouly over-priced. You could always bolt a couple of wooden planks to the framework and sit on that, but after a couple hours seat time, your arse will thank you for spending a bit of money for decent padded seat.
It's just the nature of these beasts.
/ Seat for a 955
I don't mind model specific parts costs so much, I've been involved in business myself and knows what it maintains to run a business, maintain a supply of spare parts (especially for discontinued items), etc.
But a tractor seat? Really? All I'm asking for is a cheap generic seat to bolt in.
/ Seat for a 955 #8
This showed up on my doorstep earlier today. It's going on my 955. I'm sure my backside and my back will thank me for it. It's a Milsco XB200 highback.
/ Seat for a 955 #9
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=202054"/>
Where did you get it from ?
How much ?
Does it come in black... ?
(2) 60 GAL POLY SIDE MOUNT TANKS (A63291)
(2) 60 GAL POLY...
2018 SHERP PRO1000 AMPHIBIOUS ALL TERRAIN VEHICLE (A63276)
2018 SHERP PRO1000...
2017 Volvo VNL T/A Sleeper Truck Tractor (A61573)
2017 Volvo VNL T/A...
2015 Cat D6T LGP Dozer (A62679)
2015 Cat D6T LGP...
UNUSED WOLVERINE RCR-12-84W-84" HYD ROCK RAKE (A64281)
UNUSED WOLVERINE...
UNUSED WOLVERINE 3PT QUICK HITCH (A64281)
UNUSED WOLVERINE...
