3-Point Hitch Top Link ?
   / Top Link ? #1
jgheck
Wisconsin
BX23
I want to put a Hydraulic Top Link on a L3700SU and want to know the size of the cylinder to purchase.
I do not have the tractor here and need to know what the length of the top link is when fully closed and fully extended. Than I can order a Top Link cylinder to put in there. The L3700 is suppose to be the same frame as the L3400 and I believe the same as the L3800. I could not find that information in the specs on the tractors. I also could not find it on any of the past posts. I appreciate if someone could give me that information.
Thank you, this site has been very helpful to me.
   / Top Link ? #2
I do not believe the toplink dimensions are specific to kubota, rather they are generic and specific to category 1, not the tractor.
And are you planning on buying a cylinder and trying to make your own??? Because they make just what you need with the "ball ends" already on the cylinder.
https://www.surpluscenter.com/item.asp?item=9-5152&catname=hydraulic
   / Top Link ?
I found a couple of places that sell them all made up. I also can buy a cylinder quite a bit cheaper and weld my own links on, but would rather buy it already done. I just need to know which size. I can buy a cylinder that is 20" closed and 28" extended. I think this would be about the correct size, but want to check before ordering. The Kubota dealer says they do not offer that option on the L 3400 or L3700. He said you need to get an after market one, but he didn't know what size. It is Cat 1.
   / Top Link ? #4
Be be sure measure your top link min and max center to center. Then find a hyd top link that is the closest to your exsiting one.
   / Top Link ?
I would do that but the tractor is being ordered and I want to get this ordered so I can put it on when I get it. That is why I am asking anyone that has a L3400, L3700, or L3800 if they knew because they may have done this themselves. If not then maybe they could measure that top link for me. After reading many many posts about putting on a HTL I though someone would know the size needed. I just couldn't find that information out. I am surprised that the companies that sell these don't have a list of what model tractors there top links would fit. Sort of like in the automotive field, they can look up the model of car and find the part that you need.
   / Top Link ? #6
Just use the measurments of the cylinder in the link I gave you.
3" bore
8" stroke
19-1/2" retracted length
Be sure you account for the length of the eyes.
And I would be cautious about welding the eyes on to the cylinder.
The base would be no big deal if you disassemble the cylinder to avoid damaging the seals.
BUT the rod end I would reccomend trying to track down a threaded cylinder and a "eye" that is threaded as well. If you dont, you will have to grind the chrome off to weld on it, and then the heat of welding will probabally damage the chrome far enough down the rod to the area where the seal rides. If you dont have it re-chromed you'll chew through seals in a hurry.
And I just thought I'd also ask, but are you getting rear remotes with your new tractor. If not, it wont work, and if you are, it is an expensive option.
Have you considered the Air-over-hydraulic self contained units.
https://www.surpluscenter.com/item.asp?item=9-7960&catname=hydraulic
   / Top Link ? #7
My top link length is 27 inches center-to-center of pins for most of my implements, within an inch or so. If you had a range from 24 to 32 inches you'd be well covered.
Sean
   / Top Link ? #8
I notice they only come with a 1" diameter hole. Do they make 1" to 3/4" spacers or cylinders with 3/4" ball ends?
   / Top Link ? #9
I have a TNT set up on my Grand L 3430. It was installed by the dealer when I bought the tractor. I am not where the tractor is as I write this, but I know the cylinder bore is 1.5" and it extends 8". I don't think the body of the cylinder is anymore than 12-14". The end that connects the cylinder to the tractor is right at the end of the cylinder body making the total extended length around 22-24" from pin to pin. It is completly adequate when I use the BB or landscape rake. I recently made a carryall using the TSC frame. The TNT provides plenty of tilt to keep things from rolling off during transport, but not enough tilt if I wanted to roll things off intentionally, like firewood rounds. There are three places to pin the cylinder to the tractor, which would alter the range of extension. I will experiment with them the next time I am on my rural property where the tractor is located. If changing the pin location does not help, I plan to fabricate a deeper bracket to weld on the carryall frame.
   / Top Link ? #10
After looking at the Surplus Center cylinder referred to in LD1's second post, I should mention that my set up works off the tractor's hydraulics and operates through two rear remote valves. The cylinder in the first post is a whole different animal.
UNUSED FUTURE MINI EXCAVATOR QUICK COUPLER (A57193)
UNUSED FUTURE MINI...
2016 Ford F350 - Butler Bale Bed - 4WD - 125k Miles (A53473)
2016 Ford F350 -...
2005 Freightliner M2 106 Dumpster Carrier Truck (A55852)
2005 Freightliner...
2015 Ford Fusion S Sedan (A55853)
2015 Ford Fusion S...
2013 3400QB SUNDANCE 5TH WHEEL CAMPER (A52472)
2013 3400QB...
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
