L2185 Snow Blower Works!
/ L2185 Snow Blower Works! #1
moship
PA
Kubota L3130 HST 4x4 Kubota L4740-3 HST
I just wanted to update everyone who offered advice and assistance on installing a used L2185 72 snow blower on a L3130HST tractor.
In a word the blower is awesome! After going in reverse for many years it is really nice snow blowing moving forward. The hydraulic chute rotation and electric chute deflector seemed like overkill at first, but they are really nice to have. Pushing the control lever left past the detent to rotate the chute still seems odd, but I知 getting use to it.
The shortened fixed drive shaft (off a L4330) seems to be running smoothly and doesn稚 have any unusual dynamics. Hopefully it will stay this way.
Finding a used snow blower in January for a Grand L30 was a bit tough. This was further complicated by the fact that Kubota did not offer the 72 on the smaller frame GL30痴 for the 1st few years limiting the availability further. Finding a 62 blower (L2174A) was much easier, but did not cover my tracks. After many internet searches and phone calls I found a good price on a complete snow blower assembly. Unfortunately it was located in WI and I知 located in PA. I was a bit nervous about buying something over the phone and email. Sometimes you get a good feeling about the people on the other end and I trusted them, so we struck a deal to have it trucked to my house. I did feel bad about it being an estate sale. Hopefully the original owner is looking down and happy to see someone else putting it to work.
The snow blower arrived in a middle of a snow/ice storm package in a crate measuring 4 x 8 and about 4' in height. Getting it off the truck was a bit tricky since it could not be turned to get it on the lift gate. We had to lower it long ways by balancing it between the tractor and truck lift gate. Thank goodness for the forks I bought two days earlier! Hats off to the Kubota dealer who verified everything worked prior to crating and doing a fantastic job labeling all the bolts and putting them in separate zip-lock bags. Every part was accounted for down to the smallest cotter pin.
My tractor did not have the mid PTO, so they sold me the one off the tractor the blower came off of. Installing the mid PTO was very straight forward.
A few of the forum members went beyond the norm to help me with detailed photos and instructions about how to setup the sub frame. Thanks again guys!!!
This past Monday was the first snow fall (6-8? since getting everything installed.. After 2.5 hours of use I知 very pleased with it and very glad I went with the larger blower. The local dealer said the 72 would not work and recommended the smaller unit. After getting feedback from other forum members with similar setups and doing other research, I was very comfortable going with the larger unit despite the dealer痴 opinion.
If anyone else with a L3x30 is considering the bigger L2185 versus L2174A, I say go for it. If you are looking for used do not shy away from blowers off the larger L4x30 tractors. Everything is the same except for the mid fixed driveshaft. This is the shaft from the mid PTO to the sub frame. One can be purchased from Kubota for $255 or it can be shortened if you have the equipment. [fixed driveshaft assembly is $255 while the shaft alone can be purchased for $150 if you want to disassemble the u-joints]
Any way, I just wanted to say thanks for those who provide assistance along the way.
I like the snow blower, but anxious for spring to arrive!
In the event someone uses this thread for future reference...
The chute deflection switch was mounted in the PTO panel to the right of the seat. An available slot was used to mount the switch. Reference attached photo.
On the front of the tractor a 4 pin metal trailer connector was used along with a coiled wire to the chute deflector motor. The Quick Hitch part that stays on the tractor is drilled and tapped to accept the bracket for the metal wire connector. Reference Photo below.
/ L2185 Snow Blower Works! #3
Those are nice blowers!!!
They work well just be sure to service the shear bolt joints and be sure they are not rusted tight.
Since the blower was partially disassembled for shipment, I went ahead and seviced everything including removing the shear pins and applied a small amount of grease to them.
Since the blower was used are the shear bolts anything special? They just had common bolts in them now, but do not remember the grade off hand. ie: do the recommended shear pins have a groove cut in them?
I was really impressed with how thick the metal was on everything.
/ L2185 Snow Blower Works! #5
I think they are just grade 5, no notches. I got some from the dealer when I got it but have only had to use one in the past 3 years.
/ L2185 Snow Blower Works! #7
Most shears pins are grade 2 (no hash marks on the bolt head). 3 marks is a grade 5 and 5 marks is a grade 8. I'd make sure you use the right grade, otherwise you defeat the purpose of a shear pin. While I've never sheared a pin on my snowblower, I go through them regualarly on my post hole digger!
/ L2185 Snow Blower Works! #8
The Kubota manual says "gr 5"
Not all shear pins are grade 2!!!!!!!!!!!!!!!
Kevinj,
Thanks for clarifying the bolt grade. I checked earlier and the shear pins currently on the blower are grade 5. They are the same size and grade used on the previous rear snow blower I had, so I have a few spares available.
Thanks for all your help!
/ L2185 Snow Blower Works! #10
Hi, Moship,
Was looking at your pictures and noticed you have a loader mount installed along with the blower sub-frame. I have a Kubota L5030. I didn't know you could have the snow blower sub-frame and the loader frame on at the same time. Is there anything special you have to do to drop the blower and mount the loader?
/ L2185 Snow Blower Works! #11
Forgot to tell you, I also have the L2185A (72") blower. Have had it since 2004 and love it. I use grade 2 bolts for shear pins. I used grade 5 for a little while but sometimes the #60HD chain broke instead of the shear pin. A real bummer when your 5 miles from your shop!!
Jayhawk714,
Swapping between the blower and FEL is a simple process and the quick attach frame does not impede the use of the FEL. There is nothing special to remove the snow blower and switch to the loader.
The quick attach frame can be left in place with the loader, but ground clearance is somewhat limited. During the winter it is common for me to switch between the loader (mostly for fork use) and snow blower. Now that the snow has passed, I have removed the subframe as I need the ground clearance.
The bottom line It is simple to swap between blower & FEL use and no special adjustments are needed. Just follow the standard procedure to remove the snow blower as you do now.
/ L2185 Snow Blower Works! #13
I know on my GL40 you can have the subframe on and use the FEL. The only issue is the part of the subframe that sticks out in front of the tractor often gets in the way. If moving a pile of snow back I often find that I've packed snow into that part of the subframe. On more than one occasion it has actually picked into dirt. If you don't have a heated shop to let it melt or don't remove it it'll freeze and just be that much harder to remove.
Jayhawk714,
If purchasing the FEL you might want to consider the quick detach bucket option even if you do not currently need it. It is very handy when changing between bucket and pallet forks.
The front grill guard used with the FEL can not be used with the snow blower unless it is modified. Some folks swap between grill protection and the quick hitch mount. Currently I am not using the grill guard, but will be modifying it so both the grill guard and quick hitch mount can be mounted simultaneously along with the snowblower. See post for details - http://www.tractorbynet.com/forums/kubota-owning-operating/195824-need-help-front-mount-snow.html I only mention this as an awareness and not to scare anyone.
/ L2185 Snow Blower Works! #17
I realize your post is old but im trying to set up my kubota 3710 with a 72" snowblower and the dealers are telling me the tractor is to small. I believe your 3130 is about 6 HP less than the 3710. Does it handle the snow OK and did you have to buy a factory mount or did you convert a mount from another tractor. I have found a 2185 locally but the mount is not the same one that would fit my tractor. Any info would be appeciated
JCYR,
I'm very happy witht he 72" wide blower and have not had any horsepower issues with it. With hydrostatic it is easy to adjust the proper ground speed. The subframe was the one recommended for the L-30 series tractors. It originally came off a larger tractor L4x30 series, so I just had to use a different driveshaft from the mid-pto. The subframe is made to accomodate the various wheelbases within this tractor series.
Good luck.
2025 Intersate Fabrique 12' x 6' Dump Trailer (A62613)
2025 Intersate...
TEST YOUR BID BUTTON! (A65053)
TEST YOUR BID...
Landhonor 72"Wx100L"x71"H, 6'x8' Galvanized Shed (A62679)
Landhonor...
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
HEAVYEQUIPMENT TIRES (A65643)
HEAVYEQUIPMENT...
2007 PETERBILT 386 (A65643)
2007 PETERBILT 386...
