Kubota Mechanical Advice
/ Kubota Mechanical Advice #1
Pks
Saline, Michigan
Kubota L3700SU, Cub Cadet 1430, Hustler Super-Z 66in, Vermeer 1250
I am looking for a mechanic familiar with repairing Kubota hydraulic transmissions.
Here's what I have:
My B2400HD hydraulic transmission began leaking badly during usage. It leaked up under the frame rail along side of the pump/motor housing (at the cast iron valve body). I can't determine visually any better location than that. The transmission does not show any symptoms of a mechanical failure other than it leaks oil (about 1 pint per hour during use).
I have removed all the hydraulic pipes and lever linkages in order to split the transmission from the center frame. When I removed the suction strainer, there were metal shavings and a broken o-ring (about 3/8" diameter). The o-ring felt brittle when I played with it.
Where could this o-ring have come from and could it be part of the cause that something has broken?
Thanks, Peter
/ Kubota Mechanical Advice #2
How much shavings did you have in the suction screen? It may be a
normal amount, esp if the screen has never been cleaned.
As for the missing O-ring, that is a good bet as to the cause of your
leak. More likely from the implement pump circuit vs. the hydrostatic
transmission, IMO. I do not know your tractor, but I have seen O-rings
used for some kinds of hydraulic connections, like between valves and
the sump, and with manifolds like you use to connect a loader.
For HST plumbing, the lines I see are usually hardlines with compression
fittings, or banjo fittings. No O-rings.
Some tractors use lots of O-ring face-seal fittings for the implement
pump circuit, (e.g. Deeres), but I don't think your B does.
There wasn't much in the way of shavings on the screen...just more than at the 300 hr maint interval. The o-ring is what surprised me. Due to the configuration of The transmission motor and pump assembly is one big chunk. So the o-ring must have come from inside. There is a separate implement pump & circuit but iit hangs off the side of the engine. The hydro-trans and pump assembly is under the seat and attached to the rear axel housing.
I suspect the o-ring came from the piston pump or piston motor which drives the axles.
/ Kubota Mechanical Advice #4
Any O-ring in the system could be washed downstream into the sump.
Check the implement pump's hardlines. If they have flanges, they use
O-rings. If you have a loader, there is a manifold that connects to
the main tractor casting, and it uses O-rings. FEL valves may use O-rings,
too, but I do not think that is your source since your FEL valve is mounted
to the loader mast.
2014 BMW X1 (A61574)
2012 FORD SERVICE TRUCK (INOPERABLE) (A63569)
2012 FORD SERVICE...
2005 JOHN DEERE 700H LGP CRAWLER DOZER (A64279)
2005 JOHN DEERE...
2006 Hummer H3 4X4 SUV (A61574)
2006 Hummer H3 4X4...
2013 John Deere Hydraulic Grapple Tractor Attachment (A61572)
2013 John Deere...
EZ Trail 3400 Seed Tender Wagon (A64047)
EZ Trail 3400 Seed...
