While its pretty smokey, it does sound like typical wear of the fuel system. You could always give it a compression test just to make sure (use the glow plug holes).
Another thing to check is the glow plugs. If only 5 or 6 are working, the truck will start fairly easily, but the cylinders with dead plugs will not burn as efficeintly as the hot ones. Glow plugs are wear items, are fairly cheap, and if you go to the trouble of checking each one, it might be worth doing the compression test (just like a gasser, MAKE SURE TO REMOVE THE POWER WIRE FROM THE INJECTION PUMP!) and replacing the glow plugs.
GM used AC Delco plugs (g-90?) that would swell in the head. Don't know if the Ford glow plugs do the same. If you remove them, be very careful not to break the ceramic tip off into the cylinder or precup. If they resist at all once the threads are free, they may be swollen. Maybe someone who has doen glow plugs on the 7.3 can chime in here. Or check with your diesel shop of choice.
The fact that the PO knows about and has done preventive maintenance to the cooling system is great.
That link didn't mention anything about being a certified Stanadyne shop (I think Stanadyne was the injection system manufacture for those motors, but I'm not sure), but you could call and ask. Maybe the parts are new. Prices are great though. I might use them for my truck!
