3-Point Hitch jd2305 - CountyLine PHD, yes or no?
/ jd2305 - CountyLine PHD, yes or no? #1
freddy3
jd 2305
Does anyone have any first hand experience with TSC's CountyLine post hole digger on a JD 2305? I'm looking at the digger with 12" auger. TSC is local (20 miles) and carries the auger tips, edges, etc.
/ jd2305 - CountyLine PHD, yes or no? #2
Here's another angle.... I just bought a Leinbach post hole digger with 12" auger from Everything Attachments, delivered to the house for $645. The 12" auger is heavy duty. I have used the Leinbach's before and they work good. Just another angle.....
/ jd2305 - CountyLine PHD, yes or no? #3
Freddy3, I can't say I have "first hand experience" with the exact TSC unit you are looking at, but... I have a JD 2210 (very much like your 2305) and a Farm Star PHD from Quality Farm & Fleet, the standard mustard yellow color (unable to find a model number - it's either a PHD500 or PHD720). It is virtually identical to the one TSC carries now for $469. My 2210 ran it great... I know there are attachments we need to worry about being specific for a subcompact, but this post hole digger is not one of them IMHO.
Mark
/ jd2305 - CountyLine PHD, yes or no? #4
I have one. I have used it to dig about 20 6" holes. My place has a lot of rocks and I busted about 3 shear pins. But the PHD has been rock solid so far..:thumbsup:
/ jd2305 - CountyLine PHD, yes or no? #5
I used a 12" auger from TSC behind my 31hp Deere 820, worked fine till I snagged a rock, tore up the auger then broke the shearpin. I will say it is best to invest in good augers as the cheap ones are too flimsy.
/ jd2305 - CountyLine PHD, yes or no? #6
I got my PHD from TSC last fall, with a 9" auger. Unit was actually
manufactured by Speedco of Colorado. Appears to be a decent unit.
Have had no problems. Mine is mounted on a Kubota L4310.
Caught it on sale ($399), plus a 20% off coupon.
/ jd2305 - CountyLine PHD, yes or no? #7
Around here in SW,Fla TSC sells the PHD alone for $469+tax when not on sale.
CountyLine Post Hole Digger - 2100220 | Tractor Supply Company
If you got yours like you stated w/9" auger employee's there must have tought auger went with it. :confused: IMHO
BTW:Lots of PHD manufacturer's use comer gear boxes which are good but I believe made in "China":(.
Boone
/ jd2305 - CountyLine PHD, yes or no? #8
Do you have the "updated" transaxle housing on your 2305?
The reason I ask is that there have been several reports(here on TBN), of the aluminum transaxle casings breaking apart while using PTO implements.
/ jd2305 - CountyLine PHD, yes or no? #9
... BTW:Lots of PHD manufacturer's use comer gear boxes which are good but I believe made in "China":(.
Boone
I have begun to wonder if anybody sells a Cat 1 implement with a domestic gearbox. I suspect the answer is "no", but I would be very happy to be wrong on this one.
I used to work at a facility that made it's own gears for it's procucts. Lots of capable and well compensated employees at that place. It is gone now, a victim of the race to the lowest price.
-Jim
/ jd2305 - CountyLine PHD, yes or no? #10
I have one. Have put in 40 9" holes & it's been working good.
2019 ALLMAND LIGHT PLANT (A60736)
2019 ALLMAND LIGHT...
BRAD CO. TRENCHER (A60736)
BRAD CO. TRENCHER...
2013 FREIGHTLINER CASCADIA (A60736)
2013 FREIGHTLINER...
2015 GENIE GTH-1056 TELESCOPIC FORKLIFT (A52709)
2015 GENIE...
2020 DRAGON ESP 150BBL ALUMINUM (A60736)
2020 DRAGON ESP...
2025 AGT Industrial MX-CRT23 (A60463)
2025 AGT...
