3-Point Hitch jd2305 - CountyLine PHD, yes or no?
   / jd2305 - CountyLine PHD, yes or no? #1
freddy3
jd 2305
Does anyone have any first hand experience with TSC's CountyLine post hole digger on a JD 2305? I'm looking at the digger with 12" auger. TSC is local (20 miles) and carries the auger tips, edges, etc.
   / jd2305 - CountyLine PHD, yes or no? #2
Here's another angle.... I just bought a Leinbach post hole digger with 12" auger from Everything Attachments, delivered to the house for $645. The 12" auger is heavy duty. I have used the Leinbach's before and they work good. Just another angle.....
   / jd2305 - CountyLine PHD, yes or no? #3
Freddy3, I can't say I have "first hand experience" with the exact TSC unit you are looking at, but... I have a JD 2210 (very much like your 2305) and a Farm Star PHD from Quality Farm & Fleet, the standard mustard yellow color (unable to find a model number - it's either a PHD500 or PHD720). It is virtually identical to the one TSC carries now for $469. My 2210 ran it great... I know there are attachments we need to worry about being specific for a subcompact, but this post hole digger is not one of them IMHO.
Mark
   / jd2305 - CountyLine PHD, yes or no? #4
I have one. I have used it to dig about 20 6" holes. My place has a lot of rocks and I busted about 3 shear pins. But the PHD has been rock solid so far..:thumbsup:
   / jd2305 - CountyLine PHD, yes or no? #5
I used a 12" auger from TSC behind my 31hp Deere 820, worked fine till I snagged a rock, tore up the auger then broke the shearpin. I will say it is best to invest in good augers as the cheap ones are too flimsy.
   / jd2305 - CountyLine PHD, yes or no? #6
I got my PHD from TSC last fall, with a 9" auger. Unit was actually
manufactured by Speedco of Colorado. Appears to be a decent unit.
Have had no problems. Mine is mounted on a Kubota L4310.
Caught it on sale ($399), plus a 20% off coupon.
   / jd2305 - CountyLine PHD, yes or no? #7
Around here in SW,Fla TSC sells the PHD alone for $469+tax when not on sale.
CountyLine Post Hole Digger - 2100220 | Tractor Supply Company
If you got yours like you stated w/9" auger employee's there must have tought auger went with it. :confused: IMHO
BTW:Lots of PHD manufacturer's use comer gear boxes which are good but I believe made in "China":(.
Boone
   / jd2305 - CountyLine PHD, yes or no? #8
Do you have the "updated" transaxle housing on your 2305?
The reason I ask is that there have been several reports(here on TBN), of the aluminum transaxle casings breaking apart while using PTO implements.
   / jd2305 - CountyLine PHD, yes or no? #9
... BTW:Lots of PHD manufacturer's use comer gear boxes which are good but I believe made in "China":(.
Boone
I have begun to wonder if anybody sells a Cat 1 implement with a domestic gearbox. I suspect the answer is "no", but I would be very happy to be wrong on this one.
I used to work at a facility that made it's own gears for it's procucts. Lots of capable and well compensated employees at that place. It is gone now, a victim of the race to the lowest price.
-Jim
   / jd2305 - CountyLine PHD, yes or no? #10
I have one. Have put in 40 9" holes & it's been working good.
2013 FREIGHTLINER CASCADIA(INOPERABLE) (A48992)
2013 FREIGHTLINER...
2008 FREIGHTLINER COLUMBIA 120 DAYCAB (INOPERABLE) (A48992)
2008 FREIGHTLINER...
2016 ISUZU NPR 16FT BOX TRUCK (A45679)
2016 ISUZU NPR...
2025 JMR 40in Stump Bucket Skid Steer Attachment (A49346)
2025 JMR 40in...
2019 Takeuchi TL10V2 Skidsteer Loader (A49251)
2019 Takeuchi...
5/16" 7ft G80 Chain Sling Double (A47371)
5/16" 7ft G80...
