Replacement blades for 7-Iron deck
/ Replacement blades for 7-Iron deck #1
JDgreen227
Super Member
Central Michigan
4210 MFWD Ehydro--'89 JD 318
My 2002 vintage 60-inch 7-iron deck still has the OEM blades, I put about 80 hours a year on the deck mowing and sharpen them when I pull the deck in late fall, and again about 40 hours into the mowing season. Yet I am not happy with the performance of my deck, because my tractor is a 4210 instead of a 4310, the absolute maximum height of the deck cut is only 3 1/2 inches...and the blades do not chop the grass up very well, no matter how many times I run over the clippings, I still spend a lot of time raking so the clippings don't mat the lawn.
Can anybody advise me what replacment blades to buy that will chop the grass up better than the OEM set will? About the deck height, when I was ordering my tractor, I asked the salesguy how high the 7-Iron MMM would cut, he said up to 6 inches, but I didn't inquire how high it would cut on the 4210 I purchased...the 4310 will cut the 6 inch height the salesguy informed me of. GRRRR.
For what it's worth, when my JD was delivered, the MMM was installed wrong and would only cut 2 1/2 inches maximum in the front...whover designed the installation of the MMM along with the FEL and hood guard screwed up...it is almost impossible to get the front lift lever into place because of the interference. Thanks for listening to my rant.
Would appreciate any advice about replacement blades....
/ Replacement blades for 7-Iron deck #2
Did you check with JD dealer about blades? They may have a more aggressive mulching type blade.
I have a JD 3720 with the 72" 7 Iron MMM deck and it will only raise to max height of about 3-3/4 inches but I got the smaller R4 tires so it would fit into my garage door. I believe the optional larger tires would raise the deck height several inches depending on which tire, ie turf, larger R4, R1, etc.
I use a lawn sweeper to gather up clippings for heavy grass. It works great behind either the ATV or Deere 3720. I purchased it at either Lowe's or Sears. Very good investment if you have a large lawn.
If you have the OEM Deere part # for blades, here is a link to a cross-reference for Gator/Oregon blades if you're interested.
Passportョ: OEP Power Search by OREGONョ
Thanks, guys, for the tips and the link to Oregon...my OEM part number is M128485 and the link search function gives me two blades that look more aggressive than the OEM blades...will order a set. I'd upsize the front tires on my tractor to raise the front end a little, problem is the OEM tires are already so close to the MMM front gauge wheels I cannot make them any larger...and it would probably screw up the 4wd syatem. As for a lawn sweeper, I mow about 4 1/2 acres...would require me to empty the sweeper a LOT.
Appreciate the prompt and helpful advice, thanks again.
/ Replacement blades for 7-Iron deck #5
I'm mowing 5 acres of lawn and so purchased the largest sweeper but still have to empty more than I'd like. It's a whole lot easier than raking. Sometimes I mow over the area 2 or 3 times (to mulch) and don't bother sweeping or only sweep where most of the material is. Of late I just mow before the grass gets very long and then don't need to sweep or to run over it multiple times.
/ Replacement blades for 7-Iron deck #6
I will note that the Gator blades turn clippings practically into a powder. Basically airborne whens it's real dry, or a glob you can't do much with if wet. This may or may not be problematic for you.
Thanks, I rarely have to mow when wet except in early spring...don't mind doing a little raking but thankfully most of my grass isn't very thick.
/ Replacement blades for 7-Iron deck #8
If you go through the Deere dealer for your gator blades, I recommend you do not let them talk you into the "predator" blades.
/ Replacement blades for 7-Iron deck #9
Giant Vac used to make a pull behind vac that would hold my 2.3 acres easily and was extremely easy to dump. Two wing nuts and drive away. Less than 30 seconds to complete a dump cycle. I had one I finally traded off for a gun because I use a blower that mounts (and powered by) my lawnmower.
David from jax
Thanks for the tip !!!!
Ordered a set of JD Gator mulching blades on Ebay last night, $49, free delivery, no sales tax...the Ebay seller listing said they were $95 retail for a set of 3, plus I would pay 6% sales tax and $5 for fuel to get to the dealership. Thanks again, everyone.
/ Replacement blades for 7-Iron deck #12
Gees, what a deal. Let us know your take on those new Gator blades when you get to use your mower. I'm about due for new blades and leaning towards the Gators but grass cutting here isn't for a couple more months. :thumbsup:
Ditto on mowing here, we have 16 inches of new snow so far this week !!!
/ Replacement blades for 7-Iron deck #14
Ya alot of white **** here and another winter storm warning in effect now but I wondered if you can sharpen these gator blades easily? Anyone know?
I could be wrong but from what the pics look like and the description of the blades they don't have any more cutting edges than the OEM JD blades do. I may be old fashioned but have always used nothing but a set of files to sharpen my OEM blades, never use a grinder. Perhaps thats why I got 8 years use out of them and they still have a lot of material left.
/ Replacement blades for 7-Iron deck #16
Sharpen the gator blades same as any other. The "teeth" on the back will eventually wear down, especially in sandy ground. A they do, you lose the recirculating action that causes the mulching effect.
/ Replacement blades for 7-Iron deck #18
I have a 3520 and switched from the 'standard' Deere mulching blades to the
Gator blades. Absolutely a must-have - they did a much better job of mulching and
the amount of wet clumps and blow-out was greatly reduced. Our grass is
Blue Grass and the ground tends to be damp due to irrigation - even when cutting
very late in the day on non-watering days.
One question for anyone: Has anyone tried 'X' blades? These are two sets of
blades forming an 'X' - just like the double blade option on Dixie Chopper.
Update here:
I am very unhappy with the performance of my Gator blades...they cut only marginally better (10-15%) than the 8 year old standard blades do in short, dry grass, and there is ZERO IMPROVEMENT when cutting tall or wet grass. This despite running the MMM at PTO rpm (2600). I guess they were worth the $49 I paid as they cut as well as the OEM set did, but I was hoping for finer cutting so I don't have to rake so much grass.
Just wanted to post my opinion...the resharpened OEM blades were on the deck for the first 30 hours of mowing this year, it has rained 8 days out of 10 since the beginning of April here so I get way behind in mowing. I had to power wash about 20 pounds of grass off the underside of the deck yesterday and switched blades then. I was truthfully hoping for much better cutting performance than they deliver....
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
John Deere Cotton Picker Catwalk Floor and Railing (A63116)
John Deere Cotton...
2022 Timpte 1424 All-Aluminum Equipment Trailer (A63118)
2022 Timpte 1424...
2023 John Deere 6R 145 Tractor (A63109)
2023 John Deere 6R...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2019 CHEVROLET...
