Converting trailer to ez-lube?
/ Converting trailer to ez-lube? #1
PapaPerk
USA
Kubota L3830, Ford Golden Jubilee, 1939 Sears Economy, Polaris Ranger 400, Honda Foreman 450 ES, 2004 Dodge Diesel 3500
Hello,
I have CornPro 14K lbs equipment trailer that has Dexter Torsion Flex axles. Has anyone ever converted their hubs over to the ez-lube system? The ez-lube axle has a hole drilled in it for grease to flow into the bearings.
Any info would be much appericated.
/ Converting trailer to ez-lube? #2
Hello,
If you are planning to drill the spindle out then drill a grease hole do not do it. They are hardened. I simply put Buddy Bearings on my 18' car haul trailer like you would have on a boat. Cheap and easy solution. Cost about $20 per set. Just do not over-grease them.
Chris
/ Converting trailer to ez-lube? #3
Chris
I think you mean "Bearing Buddies"
/ Converting trailer to ez-lube? #4
Vise Grips, adjustable pliers. Kleenex, facial tissue. Reese Hitch, ect. That is the brand name of one company that is a big manufacture of them. I have them on many many trailers under 10 plus names. You get the point.
Chris
/ Converting trailer to ez-lube? #5
EZ Lube and Bearing Buddies are two different concepts for two different tasks. One keeps the water out and the other flushes the old grease out the front while lubing the bearings from the inside race outwards.
The more desired conversion for the 14K trailer would be going to oil filled hubs.
David Kb7uns
/ Converting trailer to ez-lube? #6
Chris
Yep. Should have figured on the copy cat concept of marketing. Usually, people go with what they have heard of, or have seen the most. And David is correct, the oil bath is definately the best.
/ Converting trailer to ez-lube? #7
I agree with the oil bath. I never think of it because 9 out of 10 trailers I deal with are boat trailers and they have not made there way to them yet.
Do love the disc brakes the last 5 year or so. I will never own drums again if I can help it.
Chris
I read about the bearing buddies. My concern is the grease never reaches the in board bearing. The ez-lube greases from inboard out, flushing out old grease.... as someone mentioned.
Looks like I may just clean and pack the old fashioned way.
/ Converting trailer to ez-lube? #9
It will push the grease thought the outer bearing to the inner. If over greased it will push out the seals.
Chris
/ Converting trailer to ez-lube? #10
The key to not blowing the seals in the Ez-lube system is folowing the instructions by jacking the wheel up and spinning the wheel while pumping the grease in. A different colored , compatible grease helps as you can see the change as the grease is exchanged.
David Kb7uns
/ Converting trailer to ez-lube? #11
I have Dexter axles (torsion) and they have all come with the drilled axles. Grease enters the rear and then is pushed to the front. Wonder why yours is different....
/ Converting trailer to ez-lube? #12
The torsion axles can be ordered either way, the standard is without them.
There is very little difference in cost, but some trailer builders will save a buck.
/ Converting trailer to ez-lube? #13
My car hauler and enclosed race trailer both have the EZ-Lube, but I never use them. Just a accident waiting to happen in my opinion, I just remove, clean , INSPECT, and repack every year. That way I know the bearings are in good shape. Plus I can inspect the brakes at the same time.
/ Converting trailer to ez-lube? #14
I also have the EZlube dexters and am pretty afraid to use them. Always feels like I'm pumping grease into the brakes.
2019 Peterbilt 567 Quint Dump (A62613)
2019 Peterbilt 567...
2014 Ford F-550 Altec AT40M 40ft Material Handling Bucket Truck (A61568)
2014 Ford F-550...
New 11'x19' Metal Garage Shed (A62679)
New 11'x19' Metal...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A62130)
(INOP) 2013 MACK...
2007 Ford Taurus Sedan (A61574)
2007 Ford Taurus...
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
