BX HST Fan upgrade kit
/ BX HST Fan upgrade kit #1
Kellogg, Idaho
Kubota BX24 TLB
I ran across a thread that talked about a BX HST Fan upgrade kit. My eyes raised and read about an upgrade protection kit available to protect that little gem.
I guess Kubota has had a few issues with a stick or somethig killing the little $12.00 part that equals to about $500.00-$600.00 labor bill to replace it the right way
So this morning I called 3 Kubota dealers and guess what? 2 of the 3 didn't know anything about it the 1 who did took 15 minutes to find a part number then another 10 minutes to locate it The 2 that didn't know about it after my education, they were able to get info after a couple of call backs they were able to find the part. Why don't all dealers know about this?
This cost for the kit is about $35.00. I am sure it didn't cost Kubota anywhere near that ( I could be wrong ). Now this is just me thinking with the amount we have spent to buy our toys (Oops mechines) that Kubota could provide them to us as a recall type of thing considering they are a needed item to protect fan and now part of the new BX tractors.
Now please don't get me wrong I LOVE MY KUBOTA and would buy another one if the situation ever presents itself again.
/ BX HST Fan upgrade kit #2
Kubota Oz don't even have 'em in the country . Waited 10 weeks
for mine to show up via the Melbourne shipping container . Then
before leaving the Dealer , I thought I'd open its box ; no bolts/nuts
included !
/ BX HST Fan upgrade kit #3
I'm certainly missing something in these posts. Like a description of what is in this kit, a part number and a picture of the kit.:confused:
/ BX HST Fan upgrade kit #5
http://www.tractorbynet.com/forums/...ta-has-upgraded-hydrostatic-transmission.html
We discussed an upgrade Kubota made to the "protection" cover last year.
Is this what you are referring to? The protection plate pictured?
The photo in OrangeRidge post shows the older style plate.
In the thread above, you'll find the actual Kubota part number.
Calling it an "HST fan upgrade kit" is confusing. Only the shield was slightly upgraded.
Guys are still putting sticks through their fans, regardless.
/ BX HST Fan upgrade kit #6
I can't see where that is doing much good at all. I don't think I would waste my time and p--- $35 away. A full coverage plate is about $50 if you can make one and they are real easy to make. Also easy to take off and on.
/ BX HST Fan upgrade kit #7
I've added the Kubota part to mine. Its not the best, but I'm sure it helps. Its also not really in the way when hooking up the mower deck or changing the HST filter.
/ BX HST Fan upgrade kit #9
Second gen protection better than first...but, I'd still put my money toward full underside protection...there's also the hydro filter...probably just me, but I prefer to "bombproof" underside of mine.
Ultimately it depends on how each of us uses our BX...but it seems that most who have lost fans weren't working in "hostile" conditions...more like random stick or brush ate fan...
I'm sorry folks :( Yes this was what I was refering to.
/ BX HST Fan upgrade kit #11
No apology needed. Yes, Kubota is now installing a slightly larger version of the fan shroud, but as most guys here will tell you, (as will the Deere and Massey guys) these little fans are vulnerable, no matter what. Full underbody armor is the way to go if you ever take your mowing deck off or work in tough country that the engineers who designed the BX likely never envisioned folks doing. Even then, that fan is what it is. Wouldn't even care so much, if it were a ten minute R $ R. Sadly? Nope.
/ BX HST Fan upgrade kit #12
bp fick,
The plate I made can come off in less then a min. All I have to do is pull 2 spring loaded pins in front, let mower arms down, pull 2 more spring loaded pins, and then pull plate out. I do lay a 4X4 block on the floor so it doesn't tilt to much to one side, so the pins go in and out easy.
48 Inch Farm Jack (A65583)
48 Inch Farm Jack...
2016 Cadillac CTS Sedan (A64557)
2016 Cadillac CTS...
2009 Ford F250 (A66408)
2009 Ford F250...
Welcome to the Farm Metal Sign (A65583)
Welcome to the...
EZGO (A64557)
EZGO (A64557)
KL480 Ventrac tiller
