Frontier 1067 spreader non i-match
/ Frontier 1067 spreader non i-match #1
dellwas
Okay gang. Found a Frontier 1067 on Kijiji, sorta like Craig's List. Guy says he never used it, comes with an agitator, for $650. Problem is that it is designed for i-match, which I don't have. I do know that the i-match option has to be ordered from the factory, when the spreader is ordered, bit I don't have i-match. Anyway to make this work with just the 3-pt hitch, by taking off a bracket, etc?
/ Frontier 1067 spreader non i-match #2
Just put it on like you dont have a iMatch, it will just take time and practice.
Thanks, Ed, figured it couldn't be much, option is only $9 from Deere.
/ Frontier 1067 spreader non i-match #4
And as soon as you can swing it, consider treating yourself with an iMatch. Doubt you will regret it. :)
/ Frontier 1067 spreader non i-match #5
Even though guy says its new how does it look ?Has it been outside long ? Make sure gates operating ok and are not rusty or prone to give valuable seed,fert,ect. leaks.My seed spreader sleeps inside in shop,well lubricated and clean.Make sure your getting the correct pto shaft with it.
Boone
Yup, but that will be in the "Fall" budget :licking:
Good points, and I've got questions in to the owner on where it is stored.... Hope to get away this weekend to go have a look, depending on the weather.
Boone
/ Frontier 1067 spreader non i-match #8
Kind of a late question but what parts do you grease and or lube? $650 seems like a good price BTW.
Thanks
/ Frontier 1067 spreader non i-match #9
Kind of a late question but what parts do you grease and or lube? $650 seems like a good price BTW.Thanks
http://worksaver.com/Manuals/cs-series.pdf
SS gearbox should have grease fitting.
Also pto shaft u-joints.
$500 in top condition sounds better to me.Seen the ones (different brands of course)at local TSC stores sometimes what seems like forever sit outside and rust.
Boone
Deutz F3L914 3-Cylinder Air-Cooled Diesel Engine - 54 HP - Pump Takeout (A63689)
Deutz F3L914...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
2017 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59911)
2017 FREIGHTLINER...
2003 Ford F-350 Flatbed Chemical Sprayer Truck (A61573)
2003 Ford F-350...
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
Club Car (A59231)
Club Car (A59231)
