GC owners check your lower coolant hoses!
   / GC owners check your lower coolant hoses! #1
Wacky
West Virginia
2010 GC2610
I thought I should start this under a new thread.
I have received a campaign about the steering cylinder mounts on the right side of the machine being mounted backwards, which I posted on another thread. But, there was also another thing included with that campaign, the lower hose is rubbing the control lever on the pump assembly, to the point where it may fail. These include the following machines:
MFGC2600 1st-JVC93222
MFGC2610 1st-JVC93224
MFGC2400 1st-JVC03213
MFGC2410 1st-JVC03221
Mine has the hose, and the mount issue. The hose is nearly wore through at only 40hrs!
Just wanted to give you all a heads up:thumbsup:.
   / GC owners check your lower coolant hoses! #2
Thanks Wacky,
Looks like I'm one of those serial numbers. I checked on it today and sure enough mine is also just about rubbed through. Is this a notification you received in the mail? Should I wait until I receive something or call my dealer or fix it myself? I only have 29 hours.
   / GC owners check your lower coolant hoses! #3
This reminds me of when some of the original 2300's had the excess end of the throttle cable left too long. It would poke the upper radiator hose until it leaked.
   / GC owners check your lower coolant hoses! #4
I may be having a brain fart, but what do you mean by 1st? Mine starts with JTC, does that mean I should be OK.:confused2:
I would think so. I think it is all the ones that start with JVC.
Here are some pics:
   / GC owners check your lower coolant hoses! #7
Wacky, I have JUC04114, and just checked it. The throttle linkage has been rubbing the lower radiator hose. After 86 hrs, there's some wear on the hose, so I added another tie wrap to keep the hose away. I think all GC owners may want to check this one. Thanks for passing this info. along to us.
Dave K.
   / GC owners check your lower coolant hoses! #8
It sounded as though this fix only applied to 2400 and 2600-series tractors, but I just took a look at my 2310 to be sure....
They did use a different set-up on 2300-series models, so we don't have anything to worry about...:)
Good to know, in any case.
   / GC owners check your lower coolant hoses! #9
I have a 2410 JTCxxxxx with 114 hrs and my hose has a wear issue from that lever. Going to tie back & protect .
Thank you for the post , may never of found that until it was to late !!!!
Dave K.
I guess it must mean all CG 2400 and 2600 machines. :confused:
2024 New Holland T8.410 MFWD Tractor (A52128)
2024 New Holland...
2017 Ford Escape AWD SUV (A50324)
2017 Ford Escape...
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
