Comparison L2800 / L3200 compared to JD 3032E
/ L2800 / L3200 compared to JD 3032E #1
rarvesen
Member
Central Texas (Texas Hill Country)
Did anyone that purchased a L2800 or L3200 consider a John Deere 3032E? I'm finding the John Deere to be $1000+ less, which I did not expect. Do you think the 3032E is a comparable model to the L3200? I would be getting a FEL with the tractor.
/ L2800 / L3200 compared to JD 3032E #2
L2800 & L3200 have higher three point lift capacities and both weigh more then the JD.
What else?
DevilDog
/ L2800 / L3200 compared to JD 3032E #3
Re: Smaller rock bucket for 3032E / 305 loader
Quote:
Originally Posted by rarvesen
I am looking into a rock bucket for the 3032E with 305 loader. Do you think the 66 inch John Deere rock bucket is too large for this loader? Do you know of options for a smaller rock bucket, something with less depth around 4 - 5 foot? I can find smaller rock buckets but they require a skid steer universal quick attachment, is there an option to use these buckets on the 305 loader?
that is where deere gets you. you are stuck buying there attachments were as NH and Kubota have skid steer attachments and you can buy attachments any where
/ L2800 / L3200 compared to JD 3032E #4
Compair the specs. The kubota is a bigger tractor. Only YOU can decide if that is worth the extra grand.
Some of the key specs are
Kubota weighs ~500lbs more
Kubota has more GPM at the pump
Kubota will lift ~100lbs more on the 3PH
Kubota has larger front tires (smoother ride)
Loader say they lift about the same but the Kubota lifts 10" higher and has a good bit more rollback force
Also, kubotas competitive comparison says their is NO backhoe avaliable for the 3032. Not sure if it is true, but may be a factor for you as well.
Check these out
http://kubota.com/assets/product/comps/L3200/L3200_L3800 Optional Implement Comparison.pdf
http://kubota.com/assets/product/comps/L3200/L3200_L3800_Comps.pdf
/ L2800 / L3200 compared to JD 3032E #5
It is true, you also can't remove the loader and I think there are no rear remotes available (could be wrong).
You could probably buy the L2800/L3400/L3700 left overs as a better price. The L32/3800 are just starting to roll.
This is turning out to be a real problem. I really need a light weight rock bucket similar to the 54" or 60" Virnig, but I'm having a problem finding one. The buckets that will attach to the John Deere are not deep enough, or weigh too much. I'm looking into an attachment adapter, but this is definitely a disadvantage for my situation.
@LD1 - thanks for the specs, I did not find that in my research.
Thanks for all of the ideas / suggestions, I really appreciate everyone taking the time.
/ L2800 / L3200 compared to JD 3032E #7
have you contacted them to see if they can do one in JD quick tach??? worst they can do is say no..
/ L2800 / L3200 compared to JD 3032E #8
I looked at the 3032E and did not like the look and feel of the construction. The L3200 seems to offer much more tractor for the money, even if it is a few bucks more. For most people, this is a long term investment and I don't see the 3032E holding up for 10 years.
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2007 JLG 2630ES ELECTRIC SCISSOR LIFT (A59823)
2007 JLG 2630ES...
Sdlanch 20'x20' High End Carport (A60463)
Sdlanch 20'x20'...
Dexter trailer axles (A61567)
Dexter trailer...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
ASSET DESCRIPTIONS & CONDITION (A59906)
ASSET DESCRIPTIONS...
