Snow Equipment Owning/Operating Interesting Snow Blower !
/ Interesting Snow Blower ! #1
Scrambler82
SoCal
Mahindra Max 28XL, HST, TLB
I know you guys are in to more realistic toys but this was e-mailed to me and I thought you guys, especially in New England, could use a laugh.
E-Mail:
I'm tired of shoveling snow. I'm thinking of getting one of these babies!!
454 cubic inch big block Chevrolet V8 produces 412 horsepower, 430 foot pounds of torque and can throw snow 50 feet at just 3500 rpm.
And now for the rest of the story....
If you're tired of anemic, one-lung snow blowers with their slipping drive belts, you might consider Kai Grundt's V8 snow blower, which raises the bar on the traditional snow blower in every respect. With electric start, electric block heater, antifreeze heater and eight cylinders, it has no drive belts to freeze up and you'll never get bored with the job. Nor will you get cold, as the machine has been ingeniously designed to route the engine coolant through the handle bars, with the rear mounted, enclosed radiator keeping the operator nice and cozy.
Maneuvering the massive beast (it has a total wet weight of 912 lbs) is a breeze thanks to the hydraulic-drive 4WD skid steer on independent walking beams, which offers a zero turning radius. It's also as fast as you like, with an infinitely adjustable speed range on the drive wheels via dash mounted flow control. At the opposite end of the scale, it has more than enough torque to pull your car out of the ditch before the hydraulic motors stall!
Adding to the well-balanced feel of the unit, just 15 pounds of down force on the handlebars will lift the auger blade off the ground in order to climb stairs/walkways for ease of snow removal. Safety has been, and continues to be, paramount, with spring return to center "fail safe" type directional controls with emergency stop and tether cords.
Safety is one of the key themes, with a flashing blue light (as required by law in many areas) being the least of the safety features. None will fail to hear you with those twin throaty exhausts, which come standard with 92 decibels at the controls, though if the rumble of a V8 exhaust is music to your ears, you can obviously go much louder. Even at the standard baffling, hearing protection is strongly suggested.
The powerful yard machine lights and a dashboard with back lit gauges complete the package to ease the burden of this normally reviled task. The custom 42 inch, two-stage auger has a Chevrolet 10 bolt truck differential with spool and a centrifugal auger clutch with shear pin protection, further adding to the image of this "automotive theme blower." As each unit is custom-built, optional extras for the snow blower are both diverse and outrageous as the base unit - there is unlimited auger choices from single to multi stage designs and various motor combinations to suit the religious preferences of the customer (Chevy, Dodge Hemi, Ford); and such exotica as a V-10 or a diesel engine or remote starting can be accommodated. And if, after a while, you feel you've outgrown the 400 horses, this particular engine is well catered for in the performance modification area, with Lunati camshaft, Milodon Gear drive, Holley and Edelbrock components to name a few; and there's always the fuel injection option too, if you feel you need to throw the snow out of the county or ensure your seat in the "neighborhood blower blingster hall of fame.
Enjoy !
/ Interesting Snow Blower ! #3
Maybe if you get one snow fall a year it would be fine but for how much snow I get in a year I would have to take a second mortgage out on the house by the end of the season to pay for it's fuel.
/ Interesting Snow Blower ! #4
Slightly larger picture.
They've gone to tracks now.
/ Interesting Snow Blower ! #5
Definitely one of the most moronic things I've ever seen.
/ Interesting Snow Blower ! #7
No kidding........ they shoulda used a 5.9 Cummins ! ;)
LOL, I'm also a little disappointed they didn't use a couple chainsaws welded to the blower for the drift cutters, they'd obviously work much better at slicing through drifts than those wimpy pieces of steel.
/ Interesting Snow Blower ! #8
First, how many people do you really reckon have anted up for one of these things?
Second, it ought to be called the "Tim 'the tool man' Taylor" model.
Anyone who owns one of these babies can be grunting away the entire time he's using it.
(2) UNUSED 27X8.50-15 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
2017 CATERPILLAR 420F2 BACKHOE (A60429)
2017 CATERPILLAR...
2016 Jeep Compass SUV (A61574)
2016 Jeep Compass...
Caterpillar 963 Track Loader Service Manuals (A63117)
Caterpillar 963...
TYE 118-610 5 Shank Ripper (A63688)
TYE 118-610 5...
2017 CATERPILLAR 420F2 BACKHOE (A64279)
2017 CATERPILLAR...
