Buying Advice GC2400 rear blade
   / GC2400 rear blade #21
I would suggest you do not mount it on the bucket.
In my opinion, the bucket on one of these is not heavy enough to do this, without eventually damaging it.
A 48" plow is not going to be wide enough to cover the width of your wheels, when you angle it. You will need 60 inches or more, to do this well....>8...
Thank for the recommendations. If I did this, it would be for strictly straight on plowing because it's too short. I've got a lot of hours behind a 4' blade on a Gravely L8, mostly on gravel so I know about the pivot point, skids and especially the impact shock when you contact something immovable ... with the L8 being I'm the rear wheels. It's probably better I look for something that fits. Boy do I appreciate rear wheels and 4x drive! Gotta find something to hang this 700 lbs of lead I have:)
   / GC2400 rear blade #22
Your welcome. Keep in mind, making a plow wider is pretty easy fabrication work.
I really took a short cut on mine, I bought 2 old Bolens tube frame, 42" plows, (readily available), and cut the ends off of one, and welded them onto the other. Presto, a light weight, but strong, 72" plow, with springs, and angle assembly.
I was not sure it would push a 72" plow. But, I thought I would try it.
It has no problem at all pushing it.
   / GC2400 rear blade #23
Nice fab job. Now you've got me thinking!
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
2014 Ford F-350 4x4 Cab and Chassis Truck (A53422)
2014 Ford F-350...
GMC 2500HD 4wd Service Truck (A55315)
GMC 2500HD 4wd...
Venetian Bronze Aluminum Mailbox Post (A54865)
Venetian Bronze...
