Rad/Bervac Factory Hyd Chute Rotator
/ Rad/Bervac Factory Hyd Chute Rotator #1
JohninCT
Central CT
Struck Magnatrac 6000, Kioti DK40SE
I recently aquired a new B74 Rad/Bervac Blizzard snowblower. Overall I think it is an awesome machine. The only thing that disappoints me is that the manual chute rotator can not seem to be adjusted in any way to make it reachable (at least not very conveniently) from the tractor seat.
I've searched and seen many of the homemade hydraulic and electric chute rotators for this type of blower on TBN. All look to be fairly easy to put together, and quite functional but I was wondering if anyone has the factory Rad hydraulic chute rotator. The owners manual shows it to be two crescent shaped pieces for a linkage actuated by a hydraulic cylinder. I believe that the dealer told me that it was about $250. So, I'm wondering if by the time I collect the necessary components and fabricate the mounting brackets, couplings, etc if it might not be worth it to just purchase the factory kit.
Anybody have one of the factory chute turners? Can you comment about it. Good? Bad? And, maybe provide a couple of pictures of it?
/ Rad/Bervac Factory Hyd Chute Rotator #2
Other owners have gone with an electrical chute rotator - In fact I am going to do the same thing..
I picked up a new 1500lb 12V electric winch that I will mount on the top of the auger box on my 73" blower. All I have to do is adapt the cable and winch drum, to rotate the chute. Also, there is the remote switch that can be mounted up near the instrument consul - allowing remote electrical operation to turn the chute in the desired direction.
The cost of the winch on sale was $48.99 - which is a steal. Works out cheaper than hydraulic and replacements if needed, readily available.Add maybe $25.00 for wire, connectors etc., for a total of $75.00 installed.
I only found out about this by scanning previous post and stumbled across the set up. Thanks to orevious poster, I should have my chute rotating easily for just $75 all found (my labour being free).
Cheers
Jim
/ Rad/Bervac Factory Hyd Chute Rotator #3
Here are a couple of photographs of another owners set up.
/ Rad/Bervac Factory Hyd Chute Rotator #4
I have that kit on a 74" blower. Works flawlessly. If you have a remote valve on your tractor that is available to control the hydraulic rotation, I'd choose that over ANY electric system in a heartbeat.
/ Rad/Bervac Factory Hyd Chute Rotator #5
I've got a b84 with factory hydraulic chute rotation. It works excellent. If you have a rear remote I think it's the way to go. Price sounds reasonable. You would probably have $150.00 just in the piston, hoses and connectors. I also have the hydraulic deflector. It actually uses the same size piston as the one for the rotation. That also works very well if snow placement is an issue. No pictures, sorry.
Scott
/ Rad/Bervac Factory Hyd Chute Rotator #8
that is just like the one i have on my frontier sb1164 , it works great a little fast but better than a hand crank . i do have the same thing minus the hydraulic ram on the shelf in the tractor shed , it's too bad you are so far away.
/ Rad/Bervac Factory Hyd Chute Rotator #10
No its a little different. I've included a picture of the dwg from the owners manual.
And I thought mine was a wacky setup.
One advantage of the one in your drawing is that it could double as a torture device.
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55853)
Year: 2016 Make...
Kubota SVL97-2 (A60462)
Kubota SVL97-2...
2024 OMEGA 2700S WHEEL LOADER (A62129)
2024 OMEGA 2700S...
iDrive TDS-2010H...
