log arch
/ log arch #1
Rockman
Franklinton NC
kioti ck20 gear
I finished my log arch today(except for the winch), it is modeled after the old Hyster arches of yesteryear. I used a set of come-a-longs for the test hitch, seems to work great.
/ log arch #2
Nice. Have you thought about adding a box to hold your chains?
/ log arch #4
Looks great:thumbsup: I've thought of building one but don't really need one, not enough trees or distance to haul home to make it really needed. Do your tires rub in tight turns?
/ log arch #5
A Well Built Piece Of Equipment.
/ log arch #6
Nice looking arch. That should make bringing in the wood a lot more productive. What did you use for the axles?
-Jim
/ log arch
Beeforty, yes the trees do rub the tires in tight turns, not a problem so far maybe I should think about adding fenders.
Baby grand, I went to the junk yard not knowing what I was looking for and came home with the rear axle from a Mercury villager mini van, I cut the axle on the bandsaw leaving 4" stubs on the hubs, works perfect, plus 15" tires.
/ log arch #8
Interesting...I ususlly just wrap a chain around the end of the log and lift it with the 3 pt. and away I go. Is there an advantagemto using the arch?
Thanks.
/ log arch
Thanks.
Yes, there are a couple advantages I know of, 1) the arch carries the weight instead of having it hang of the rear of the tractor 2)it lifts the tree/log off the ground making it easier to pull and keeping it out of the dirt mud.
Kevin
/ log arch #10
/ log arch #13
Nice Arch. Will make skidding much easier for your tractor.
Something you might want to consider for a winch. Works well for me and can be used with or without the arch. This is before paint and all.
/ log arch
plumbstraight, thats a nice winch, how big is it? Your tractor looks just like mine, is it a ck20?
/ log arch #15
Fenders won't solve that, more a geometry problem. Nice fab job:thumbsup:, do you lose traction with the weight not on the 3PH?
/ log arch #16
Hello Rockman,
The winch is a 10,000lb electric and it is a ck20s Kioti.
I did build myself an arch back in the 70's that converted to a trailer for a kubota. I have one now for my quad. It works well bringing in the wood. Will have to get out now and make one for the kioti. they do make a difference.
/ log arch
Well, I was thinking of fenders like on a cable skidder. As for traction, The traction is better with the arch. My tractor is 4x4 and with all 4 wheels on the ground all the time it works great.
Kevin
/ log arch
Plumbstraight, I thought your tractor looked like mine, my little ck20 is a work'n fool for it's size.
That is a nice winch, I would love one, but I don't see it in the budget for awhile.
Kevin
/ log arch #20
Nice looking job, a log arch is one of the best tools I have for firewood and fence posts. I use mine behind the ATV, it was built to follow in the ATV tracks.
You might find a set of deflectors in front of the wheels very handy. I added mine after a year or so of getting hung up on trees in tight corners. Now the arch just bounces to one side when you hit a tree, and keeps on going.
Where you mount the axles plays a big factor in weight distribution when you have a log hung from the arch. Mine are about 8 inches behind the arch, and actually add weight to the hitch when loaded.
I've been contemplating a bigger version for use behind the tractor, but for the stuff I cut the ATV is a lot more nimble around the woods. I've had wood up to about 16 inches on mine and it handles it with no problems. I used Chrysler stub axles, and 1.5 inch x 1/8 square tube for most of it. The boat winch is used for bigger stuff, small wood I can handle.
You can actually back up to the log, disconnect the arch and pivot it so the tongue is upright, then hook the choker and use the tongue for leverage to pull the log off the ground. Works very well.
Sean
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
New/Unused Landhonor 6ft x 8ft Galvanized Apex Roof Metal Shed (A61166)
New/Unused...
2016 Ford F-150 Pickup Truck, VIN # 1FTMF1C85GKE26496 (A61165)
2016 Ford F-150...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
New/Unused Quick Attach Skid Steer Brush Cutter (A61166)
New/Unused Quick...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
