log arch
/ log arch #1
Rockman
Franklinton NC
kioti ck20 gear
I finished my log arch today(except for the winch), it is modeled after the old Hyster arches of yesteryear. I used a set of come-a-longs for the test hitch, seems to work great.
/ log arch #2
Nice. Have you thought about adding a box to hold your chains?
/ log arch #4
Looks great:thumbsup: I've thought of building one but don't really need one, not enough trees or distance to haul home to make it really needed. Do your tires rub in tight turns?
/ log arch #5
A Well Built Piece Of Equipment.
/ log arch #6
Nice looking arch. That should make bringing in the wood a lot more productive. What did you use for the axles?
-Jim
/ log arch
Beeforty, yes the trees do rub the tires in tight turns, not a problem so far maybe I should think about adding fenders.
Baby grand, I went to the junk yard not knowing what I was looking for and came home with the rear axle from a Mercury villager mini van, I cut the axle on the bandsaw leaving 4" stubs on the hubs, works perfect, plus 15" tires.
/ log arch #8
Interesting...I ususlly just wrap a chain around the end of the log and lift it with the 3 pt. and away I go. Is there an advantagemto using the arch?
Thanks.
/ log arch
Thanks.
Yes, there are a couple advantages I know of, 1) the arch carries the weight instead of having it hang of the rear of the tractor 2)it lifts the tree/log off the ground making it easier to pull and keeping it out of the dirt mud.
Kevin
/ log arch #10
2015 New Holland T4.95 MFWD Cab Tractor (A55314)
2015 New Holland...
2014 FREIGHTLINER 108SD CONCRETE MIXER TRUCK (A59823)
2014 FREIGHTLINER...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A59230)
2019 Ford F-150...
2006 Ford F-350 Pickup Truck, VIN # 1FTWX31P16EB57079 (A61165)
2006 Ford F-350...
2012 COMPTANK ACID TRANSPORT TRAILER (A55745)
2012 COMPTANK ACID...
12' Truck Box (A60352)
