Exploding Tire Kills 8yr old boy
/ Exploding Tire Kills 8yr old boy #41
I drive past a safety cage everyday that is about 10% wider than it was new. It has caught some flying rims over the years.
/ Exploding Tire Kills 8yr old boy #44
That could have even hit him from that distance it looked like. Thanks
/ Exploding Tire Kills 8yr old boy #45
/ Exploding Tire Kills 8yr old boy #46
Having worked most of my working years as a self employed claims adjuster, I have investigated several fatal claims involving split rims. The force created by a failed split rim is incredible. I had photos of a ring that had blown directly upward and was lodged about halfway through a 2x10 ceiling joist, about 15 ' above the floor. One expert advised me the force would throw a bowling ball about 1/2 mile. Many accidents occur after the rim has been inflated and placed on the spare tire carrier. If the ring is worn or not set exactly correct, the ring blows off when the tire is pulled off the carrier and strikes the ground. Anyone concerned about using split rims should Google "Split rim accidents", that should make a believer out of you. The best answer is to replace the split rims but at a bare minimum, have them aired up in a professional cage. Good luck and be careful.
Caterpillar Quick Attach Forks (A60463)
Caterpillar Quick...
2017 FREIGHTLINER CASCADIA (A60736)
2017 FREIGHTLINER...
2019 MQ POWER WHISPERWATT DCA-25 GENERATOR (A58214)
2019 MQ POWER...
KJ K1522 Portable Restroom 1 Shower & Sink (A60463)
KJ K1522 Portable...
2025 MACK GRANITE GR64F DUMP TRUCK (A59823)
2025 MACK GRANITE...
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
